Painting On Pergo Flooring - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 11:38 PM   #1
Painting on Pergo flooring
Can Pergo be painted on? If so what kind of paint would be best to use?
SDysthe is offline   Reply With Quote
Old 07-25-2011, 11:44 PM   #2
its laminate like countertops. nothing would be durable enough. i mean you could paint it with epoxy paint, but it wouldnt be that cheap and probably wouldnt give you satisfactory results. replace it. im ripping all the pergo out of my downstairs. the cheap laminate in the discount stores looks better then the pergo that was here when we moved in. im going with 3/4 solid tigerwood.
Pergo Laminate Flooring Problem whosallen Flooring 4 07-24-2012 07:22 PM
Can I Paint a Plywood Subfloor? LMS1213 Flooring 31 05-06-2012 09:33 AM
Sub Flooring for Pergo Floor. CJMEDINA Flooring 3 08-15-2010 03:15 PM
pergo flooring avacarr Flooring 2 12-10-2008 04:17 PM
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General DIY Discussions 6 05-30-2008 03:03 PM
