Painting Particle Board Roofing In A Screen House? - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 08:14 AM   #1
Question
Painting Particle Board Roofing in a Screen House?
Hello all! Last summer we as a family put in some collaborative sweat equity and came out with a great screen house in the back yard. The roofing was done by a local contractor who chose to use particle board as the base. So now, we look up and see bare particle wood and are starting to think about painting it. I'm thinking about the variables first:
The real question: What is the best / proper way to paint particle board?
  • I want to keep the beams / joists unfinished (so spraying is out)
  • It is an outdoor setting
  • It's a ceiling / roof (if any gloss should be considered for light reflection)
  • Will I have to sand any glue / sealant on the board first?
  • Do I have to prime or will your suggested paint be a one coat type?
  • Can the imperfections of the particle surface be hidden /subdued in any way (hide the bumps)?
kRySpiE is offline   Reply With Quote
Old 04-29-2012, 09:25 AM   #2
Ravenworks's Avatar
Spray is with an exterior primer followed by a good quality exterior paint.
Ravenworks is offline   Reply With Quote
Old 04-29-2012, 09:50 AM   #3
Not painting beams
I should have added in my post:
I want to keep the beams / joists unpainted, so spraying is kind of out.
Old 04-29-2012, 10:22 AM   #4
Rewards Points: 13,458
Your going to have to prime it first with a sealing primer then paint it. Those grade marks are just going to blead through if you skip that step.
Keep in mind painted OSB looks like poop.
Tags
paint , painting , particle board , roof , screen house
Porcelain tile over particle board over concrete slab? roughtrader Flooring 9 04-16-2012 11:24 AM
A particle board sandwich?? Alvis Flooring 2 08-13-2010 10:09 AM
Particle board underlayment help diynut Flooring 5 03-07-2006 05:22 AM
My dilemma: Painting exterior of house dvarga Painting 6 08-26-2005 09:23 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
