Painting Paneling With A Sprayer? - Painting - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 09:59 PM   #1
painting paneling with a sprayer?
So I have a bunch of wood paneling in my basement. Well, proper tongue and groove boards actually. They are primed and ready to go.
I have a question as to how well a paint sprayer would work to paint the paneling. The local shops rent 5xx airlessco sprayers.
When I primed the boards, I used BIN and when I rolled the bin was thin enough to cover into the grooves. The thicker ben-moore paint I am using is not. I would rather not have to brush each groove if painting with a sprayer will work to paint the grooves.
Will this work for me? Minimal taping required ceiling and walls same color unoccupied with bare concrete slab floors.
b_corwin is offline   Reply With Quote
Old 10-04-2009, 06:19 AM   #2
Remodeling Contractor
A sprayer will work well. Do it in several thinner coats. Add floetrol to the latex paint for it to spray better. Do not thin the paint with water.
Old 10-04-2009, 08:28 AM   #3
Too Short? Cut it Again!
This is actually a good situation for spraying. If you wanted to roll it, a thicker nap cover---1" to 1.25"---would probably do the trick too although you might have to follow behind with brush just to make sure. If you spray it, Floetrol is definitely great stuff. I always add to semi-gloss for painting trim too.
uneven wood paneling joefromcal Carpentry 6 04-30-2009 09:50 PM
Painting Over Wood Paneling vomtickie Painting 8 08-01-2007 04:07 PM
Painting Paneling - Do I need deglosser? sweetsue777 Painting 7 01-30-2007 01:35 AM
