Painting Paneling With Primer In The Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 08:32 PM   #1
painting paneling with primer in the paint
Can I paint paneling with a paint with the primer in it or should I prime the paneling then paint?
ivymotes is offline   Reply With Quote
Old 05-24-2012, 08:37 PM   #2
Rewards Points: 13,300
Painted paneling will look like painted paneling, but ha it's your house.
I would clean the paneling first, then sand it with about 100 to 60 grit sand paper. wipe down again then prime with oil based primer, then any quality latex paint.
I've seen way to many times where just painting it will cause what looks like tobacco stains to run down the wall. An oil baced primer will seal it.
Old 05-24-2012, 09:10 PM   #3
ltd
Rewards Points: 536
wash paneling to remove any liquid gold ,oil soap, pledge, then rinse with clean water . when dry lightly scuff sand to degloss paneling.dust off paneling, then prime with zinsser cover stain oil primer .let dry over nite .caulk in all gaps then paint with a good quality latex paint in a satin or a flat .that's how i roll
ltd is offline   Reply With Quote
Old 05-24-2012, 09:38 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Doing paneling right now. ( well earlier today..)
Scuff sanded- good tsp ( or tsp substitute) clean, full coat of Zinnser Smart Prime, 2 top coats of Aura egg ( satin in lighter color on base and all non- panel moldings, windows etc.)
That's how i roll.
Absolutely need a real bonding primer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-24-2012, 10:05 PM   #5
Gymschu's Avatar
Rewards Points: 510
^^^^^This! Although you can USUALLY substitute a latex bonding primer for the CoverStain if you don't like the fumes.
Gymschu is online now   Reply With Quote
Old 05-24-2012, 10:11 PM   #6
Too Short? Cut it Again!
Joe, you scare me continually. If I have a 60 grit piece or more coarse piece of paper or a disc or pattern for a sander here it came in a package. Or I used one sheet on the corners of an exterior project (did not work outside much) as a first pass. Do not the surfaces you prepare with such coarse grit look a tad chewed up or something?
I hate popcorn ceilings, contemporary wallpaper borders, and cheap veneered masonite paneling. I took all down when I could. Otherwise I filled the gaps in the paneling, primed and painted as suggested. Maybe only I could tell because I knew it was there? I tried my best but it still looked, sounded or acted like cheap paneling to me.
Old 05-24-2012, 10:13 PM   #7
Originally Posted by Brushjockey View Post
Scuff sanded
60 grit I assume?
Old 05-24-2012, 10:26 PM   #8
I'm putting up nice coats- not flat- Don't want to make deep scratches that will show.
Old 05-25-2012, 05:09 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
I do believe sd was being sarcastic
To joe blow, 60 grit paper? You trying to get the stain out?
Old 05-25-2012, 12:11 PM   #10
A Little Of Everything
Rewards Points: 1,364
I'd say we have another one-hit-wonder here, but who knows...
Yes, you can use primer & paint in one to paint paneling. It's not your best option, but it can be done. Plan on using 3 coats, which means you might as well have put on 1 coat of primer, and 2 coats of top-coat, and had a better end result.
Prep it like these guys have advised (except the 60 grit paper) and do the deed.
My personal opinion would be to NOT try to fill the seams in paneling. I've done & seen a lot of painted paneling, and in my opinion it looks just fine.
Unless you are absolutely awesome at filling the seams (which most DIYers are not), it's going to be obvious that you just painted paneling. So let it be obvious.
DrHicks is offline   Reply With Quote
Old 05-25-2012, 06:14 PM   #11
chrisn's Avatar
Rewards Points: 236
Old 05-25-2012, 08:23 PM   #12
Here's the lake home I've been working on. Last coat still needed
Old 05-25-2012, 09:08 PM   #13
^ Excellent!
Old 05-25-2012, 09:21 PM   #14
Just a DIY guy
Paneling is not my first choice in wall covering, but I don't know why people like to cover up nice wood (that stuff looks like quality paneling in the photo, not like junk). But I guess that's what makes the world go round (and keeps painters in business!)
M3 Pete is offline   Reply With Quote
Old 05-25-2012, 09:31 PM   #15
In this case- home built by dad in the 60's, all paneling. Kids and family ( now in their 50's) take it over and trying to update it.
It really did scream 60's. (notice blue shag- lol. Florescent boxes going too.)
Short of rerocking whole place- this was best solution. I've already done the 1'st floor.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 05:12 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
