-   -   painting paneling with primer in the paint (http://www.diychatroom.com/f4/painting-paneling-primer-paint-144765/)
ivymotes 05-24-2012 08:32 PM
Can I paint paneling with a paint with the primer in it or should I prime the paneling then paint?
joecaption 05-24-2012 08:37 PM
Painted paneling will look like painted paneling, but ha it's your house.
I would clean the paneling first, then sand it with about 100 to 60 grit sand paper. wipe down again then prime with oil based primer, then any quality latex paint.
I've seen way to many times where just painting it will cause what looks like tobacco stains to run down the wall. An oil baced primer will seal it.
ltd 05-24-2012 09:10 PM
wash paneling to remove any liquid gold ,oil soap, pledge, then rinse with clean water . when dry lightly scuff sand to degloss paneling.dust off paneling, then prime with zinsser cover stain oil primer .let dry over nite .caulk in all gaps then paint with a good quality latex paint in a satin or a flat .that's how i roll:eek:
Brushjockey 05-24-2012 09:38 PM
Doing paneling right now. ( well earlier today..)
Scuff sanded- good tsp ( or tsp substitute) clean, full coat of Zinnser Smart Prime, 2 top coats of Aura egg ( satin in lighter color on base and all non- panel moldings, windows etc.)
That's how i roll.
Absolutely need a real bonding primer.
Gymschu 05-24-2012 10:05 PM
^^^^^This! Although you can USUALLY substitute a latex bonding primer for the CoverStain if you don't like the fumes.
user1007 05-24-2012 10:11 PM
Joe, you scare me continually. If I have a 60 grit piece or more coarse piece of paper or a disc or pattern for a sander here it came in a package. Or I used one sheet on the corners of an exterior project (did not work outside much) as a first pass. Do not the surfaces you prepare with such coarse grit look a tad chewed up or something?
I hate popcorn ceilings, contemporary wallpaper borders, and cheap veneered masonite paneling. I took all down when I could. Otherwise I filled the gaps in the paneling, primed and painted as suggested. Maybe only I could tell because I knew it was there? I tried my best but it still looked, sounded or acted like cheap paneling to me.
user1007 05-24-2012 10:13 PM
Originally Posted by Brushjockey (Post 928170)
Scuff sanded
60 grit I assume?:wink:
Brushjockey 05-24-2012 10:26 PM
I'm putting up nice coats- not flat- Don't want to make deep scratches that will show.
chrisn 05-25-2012 05:09 AM
I do believe sd was being sarcastic:whistling2:
To joe blow, 60 grit paper? You trying to get the stain out?
DrHicks 05-25-2012 12:11 PM
I'd say we have another one-hit-wonder here, but who knows...
Yes, you can use primer & paint in one to paint paneling. It's not your best option, but it can be done. Plan on using 3 coats, which means you might as well have put on 1 coat of primer, and 2 coats of top-coat, and had a better end result.
Prep it like these guys have advised (except the 60 grit paper) and do the deed.
My personal opinion would be to NOT try to fill the seams in paneling. I've done & seen a lot of painted paneling, and in my opinion it looks just fine.
Unless you are absolutely awesome at filling the seams (which most DIYers are not), it's going to be obvious that you just painted paneling. So let it be obvious. :)
chrisn 05-25-2012 06:14 PM
:thumbsup::yes:
Brushjockey 05-25-2012 08:23 PM
Here's the lake home I've been working on. Last coat still needed
http://i42.photobucket.com/albums/e3...ainting01s.jpg
http://i42.photobucket.com/albums/e3...ainting06s.jpg
http://i42.photobucket.com/albums/e3...ainting11s.jpg
DrHicks 05-25-2012 09:08 PM
^ Excellent!
M3 Pete 05-25-2012 09:21 PM
Paneling is not my first choice in wall covering, but I don't know why people like to cover up nice wood (that stuff looks like quality paneling in the photo, not like junk). But I guess that's what makes the world go round (and keeps painters in business!)
Brushjockey 05-25-2012 09:31 PM
In this case- home built by dad in the 60's, all paneling. Kids and family ( now in their 50's) take it over and trying to update it.
It really did scream 60's. (notice blue shag- lol. Florescent boxes going too.)
Short of rerocking whole place- this was best solution. I've already done the 1'st floor.
