Painting Over Wood Stained Trim - Painting - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 09:06 AM   #1
Painting over wood stained trim
We recently bought our first home and were looking to paint our wood trim white. The issue is the trim is from from when the house was first built ('88) and was never maintained or restained since then. The result is a dull sheen to no sheen on the baseboards and chair rail, and some what shiny on the window frames. In some places the wood has been worn back to it's natural state.
My question is, do we have to remove the stain, buy a deglosser, sand the wood, or simply prime and paint? The wood is in good condition, very minimal nicks or dents.
We have decided to use the BM products as they seem to offer the best coverage.
Any advice is much appreciated!
elise77 is offline   Reply With Quote
Old 06-29-2010, 10:40 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If it were me I would skip the deglosser and just scuff sand. Then I would use oil based primer for better bond on any gloss, penetration on any worn spots and to lock in any bleed from the wood and stain. Then topcoat with Regal Semi-Gloss.
Old 06-29-2010, 04:18 PM   #3
Thanks for your reply!
After sanding would recommend just simply washing the wood clean or using something like Jasco TSP No-Rinse Substitute? And do you know if there is a wait time between cleaning the wood and priming?
Old 07-02-2010, 03:09 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Just wipe it down with a damp rag, let it dry, prime and paint. As suggested an oil based primer would be optimal but I have done many , many jobs like this using Fresh Start latex primer. It will work just fine especially if you scruff sand it first
Old 07-02-2010, 03:18 PM   #5
NAV
I am not a fan of using an oil based primer on wood trim. The reason is that, especially if the wood is a softer wood, when it gets hit by something the wood dents. Oil based products dry hard and will crack/chip where as a latex based material will flex with the dent and not chip. Downside of latex primer is that it is not a good stain blocker.
make sure you sand well either way.
NAV is offline   Reply With Quote
Old 07-02-2010, 04:02 PM   #6
Would you all recommend sanding off the original stain or just smoothing the wood? I ask because the wood has been worned down to the original wood color in some areas (and because I have never had to sand wood trim before!)
Old 07-02-2010, 05:18 PM   #7
chrisn's Avatar
Rewards Points: 612
No need to sand it all off, just light go over it with maybe 120- 150 grit paper and clean off the dust.
Old 07-03-2010, 11:02 AM   #8
Great! Thanks for your help!
painting trim and base boards fabian Painting 19 10-10-2010 01:48 AM
Painting over dark stained wood tjeieio Painting 7 03-13-2010 11:40 PM
Painting wood finished trim white... leverne99 Painting 12 06-06-2009 06:31 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 02:28 PM
