Painting Over Wood Paneling - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 12:32 PM   #1
Hi Everyone,
I am going to be painting over old wood paneling in a bedroom. I was wondering what you all suggested for a primer/base coat? In the past, I have always used Kilz for dark walls (like this dark wood paneling).
Are there any other better primers recommended? It seems like these types of projects always take a few coats to cover well.
Any help or suggestions are greatly welcomed.
vomtickie is offline   Reply With Quote
Old 07-30-2007, 01:09 PM   #2
Guest
Guest
Posts: n/a
Kilz isn't a bad idea, though I would use Zinsser Cover-stain myself. You should be able to use an acrylic even, such as 1-2-3 but I think Cover-stain would give the best adhesion going over a previous oil coating, provided your paneling has polyurethane on it like I would assume.
Old 07-31-2007, 08:54 AM   #3
Good point. The paneling does have polyurethane on it. Thanks for your help.
Old 07-31-2007, 10:06 AM   #4
Darylh's Avatar
When it comes to Paneling I always give it a sanding to rough up the surphace a bit and use Kilz original oil based primer.
Darylh is offline   Reply With Quote
Old 07-31-2007, 11:55 AM   #5
So is it real paneling or fake? I have fake in my room and it helped to sand it down first.
jgeorgie33 is offline   Reply With Quote
Old 07-31-2007, 01:33 PM   #6
This is real wood paneling. It's probably about 30-40 years old.
Old 08-01-2007, 05:51 AM   #7
Guest
Guest
Posts: n/a
Yes a light sanding is never a bad idea either. Make sure you get the dust off before priming.
Old 08-01-2007, 04:06 PM   #8
Workaholic's Avatar
Rewards Points: 268
This is how i would do it as well.
Sean
Workaholic is offline   Reply With Quote
Old 08-01-2007, 04:07 PM   #9
Tired, Cold, and Damp
slickshift's Avatar
A nice scuff sanding, clean off the dust, and prime with Cover-Stain or Original (oil-based) Kilz
slickshift is offline   Reply With Quote
painting over a wood stain franko24 Painting 5 10-13-2010 07:52 PM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
Refinishing Wood paneling c4m4r0 Painting 1 05-30-2007 10:52 PM
Painting Paneling - Do I need deglosser? sweetsue777 Painting 7 01-30-2007 01:35 AM
Painting exterior wood house parasailing Painting 1 02-06-2006 01:24 PM
