Painting Over Wallpaper Liner - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 11:40 PM   #1
painting over wallpaper liner
Which wallpaper liner would work best to put on a damaged wall that will be painted over pasted or unpasted or does it make a difference
okdfarr is offline   Reply With Quote
Old 03-15-2012, 05:41 AM   #2
Rewards Points: 101
How bad is the wall damaged? Can it be skim coated with Joint compound to fix it instead of going the wallpaper liner route?
JMDPainting is offline   Reply With Quote
Old 03-15-2012, 05:48 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
http://www.flexiwall.com/pages/home_page.htm
Old 03-15-2012, 10:06 AM   #4
Too Short? Cut it Again!
Nu-Wall is another possibility I used a lot. It is a bit pricey but works great.
Until you are accustomed to working with Nu-Wall or the stuff Chris led you to, plan on lining up an extra pair of hands to help you. If the budget allowed, I would always call someone like Chris better at hanging wall coverings than me to do it.
Old 03-15-2012, 01:34 PM   #5
chrisn's Avatar
Rewards Points: 622
I did not realize nu wall was still out there and as sd said it is a real pain to install. If you are just using wall paper( liner paper), then you hang it like any other paper. It will have instructions on how to paint
Old 03-15-2012, 04:16 PM   #6
Chris, I saw that Abatron was carrying it or took it over last time I needed some of their wood restoration stuff to help a friend rebuild a weird shaped cat boat window frame that had rotted.
NuWal has not gotten any cheaper but if the walls are in rough shape and replastering the surface or something the other alternative, it can really help under the right circumstances. Obviously if there is real structural or water damage or in the case of plaster, the wall is separating from whatever is behind it? You need to address the problem and not hope covering it over will help much.
http://www.abatron.com/buildingandre...ionsystem.html
Old 03-15-2012, 04:46 PM   #7
chrisn's Avatar
Rewards Points: 622
Thanks for the link, I am glad Abatron bought them out,I always liked the wood restoration stuff. I only used the Nu wall a couple times but it did it's job well, although it was a royal pain to install
Old 03-15-2012, 04:57 PM   #8
It was probably just us. The product page promises easy installation. If it was challenging for you who hangs paper for a living and me who has certainly laid up a few boat hulls and other fiberglass projects, I would not call it easy. I would definitely recommend the stuff if it is needed though. Just be prepared for a challenge---especially if working alone.
Old 03-16-2012, 05:10 AM   #9
chrisn's Avatar
Rewards Points: 622
for sure
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 04:25 AM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 05:03 PM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 05:49 AM
Painting over wallpaper RussellF Painting 8 11-01-2006 01:42 PM
