Old 02-07-2010, 11:59 AM   #1
Painting over wallpaper?
If I decide to paint over wall paper, about 2,000 sqft, would I use a specific type of primer? Oil, shellac, water base?
Thanks in advance gto anyone who can educate me on this.
GAWG is offline   Reply With Quote
Old 02-07-2010, 03:05 PM   #2
Tacky and problematical. It will always look like you painted over wallpaper which ranks right up there with painting over cover plates or putting down nylon astroturf stuff instead of carpeting. Do not do it! If you ever want to sell the house, it will send the signal that you compromised on everything!
The wallpaper will come of easier than you think once you get going. Rent a steamer if it is antique stuff. Otherwise buy a scoring tool. Wet thoroughly with a mix of warm water and fabric softener (or pay a fortune for the wallpaper remover stuff) and get under it with a nice wide drywall blade. I grew tired of hand cramps from little spray bottles and bought a 1 gallon garden sprayer for saturating the walls. $10?
When the paper is off, prime with an appropriate primer. Apply two coats of paint store, not box store, paint. You will be very pleased you put in the extra work! You will not like what you end up with if you paint over wallpaper, I promise.
sdsester is offline   Reply With Quote
Old 02-07-2010, 08:11 PM   #3
a smart person learns from their mistakes... a wise person learns from the mistakes of others...
be wise... remove the wall paper... you will be glad you did.
if you insist on just being smart... prime a small wall with the paper on...
after the bubbles appear... you may try cutting them out ..skim lightly with mud... prime again.... then more bubbles appear.... repeat until all wall paper is removed.
It does not matter what you try for a primer... if it is wet..it will cause expansion / contraction problems.
PS. Some folks may have painted over wallpaper without a problem.... most pros will not do it.
Big Bob is online now   Reply With Quote
Old 02-08-2010, 06:03 AM   #4
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
Do it right, remove the paper.
http://www.wallpaperinstaller.com/wa...stripping.html
Old 02-09-2010, 06:51 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
On sooo many levels, ayup
slickshift is offline   Reply With Quote
Old 02-09-2010, 06:52 PM   #6
slickshift's Avatar
Ayup!
Old 02-09-2010, 11:07 PM   #7
Remove it at all costs. It will bubble when you paint it and odds are some of the bubbles will stay when the paint dries. It will bring out the seams and even make any imperfections in the drywall underneath stand out where the wallpaper may have hidden. And it will basicly make it impossible to remove once you paint it.
Old 02-10-2010, 05:50 AM   #8
You'll regret it if you don't remove the wallpaper first.
This from years of experience and bad memories from the one time I tried it, 25 years ago.
Shamus
Shamus is offline   Reply With Quote
Old 02-10-2010, 06:48 AM   #9
I absolutely agree - remove the wallpaper!!! However, if your mind is made up and you just HAVE to paint over it - use an oil based primer - water based primers tend to reactivate the glue and make an ugly job look even worse! =)
good luck!!
mazzonetv is offline   Reply With Quote
More On This Topic
Painting a house can seem like a monumental task, but it's really quite simple if you take your time and break the job down into manageable steps. Painting your own house can save you some major bucks over hiring it done. Here are some steps and tips for... Read More »
Irish Steamer Recipe
Irish Steamer Recipe by Expert Village
If you love gourmet coffee house drinks, our expert is here to show you how to make an Irish steamer in this free drink recipe video. Read More »
When you take on the job of painting your home, inside or out, the job can be made easier if you have the right kind of equipment. A paint sprayer can make the job go faster. There are different types to choose from. Read More »
Decorate your dollhouse just like you would decorate your real fantasy house. You can let your imagination run wild, without the worry of functional details or comfort of the occupants. The only guidelines to follow when decorating a dollhouse are to... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Painting after removing Wallpaper fozzie Painting 4 11-03-2009 06:59 PM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 06:49 AM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
painting over wallpaper linda mcginness Painting 4 10-28-2005 11:56 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
