Painting Over Wall Paper - Painting - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 10:54 AM   #1
Painting over wall paper
We are painting are bathroom and removed 3 layers of wall paper and some of the wood under neath that. Do I need to remove the wall paper from all the walls to have the same look or would you just leave them if they are ok. We are painting with BM collection dark green.
MillerTime is offline   Reply With Quote
Old 01-24-2009, 11:17 AM   #2
I'll give you my green painted walls for 1/2 price.
Several yaers ago my wife was going to strip and repaint our bathroom with her sister while I was away on a business trip. I came home and found very fine seams in the paint... from the wallaper underneath. I was livid. Then I found out she hired someone to do it while she hung out with her sister... who's plane ticket was on my tab.
He was a pro painter, one we had used before and exceptionally good but my problem now is we want to change the green and it's going to be even tougher to strip. Because it was a high humidity room he opted for outdoor oil based paint.
Do it right do it once! Strip it and start fresh
Chemist1961 is offline   Reply With Quote
Old 01-24-2009, 12:13 PM   #3
Knucklez's Avatar
Rewards Points: 930
you can rent/buy wall paper remover steamer. and buy a 4" wide spatula thing. works good.
Knucklez is offline   Reply With Quote
Old 01-24-2009, 06:20 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
For reasons on so many levels....
Remove the wallpaper
slickshift is offline   Reply With Quote
Old 01-25-2009, 07:14 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
If he used an exterior paint AND painted over the wallpaper,he was not much of a pro.IMO
Strip the paper
Old 01-29-2009, 02:43 PM   #6
DIY Rookie
Send a message via AIM to jpfreak33
I am in the process of stripping and painting almost every room in my house. I am not onto the Kitchen. Stripping wallpaper isnt the hard part, Fixing the walls before you paint is the nightmare. I have skim coated most of the walls I have done, its easier then tryign to find and patch all the little imperfections. It takes a lot of time but is well worth it in the end. I went to home Depot and bought a $39 wall paper steamer, works great
jpfreak33 is offline   Reply With Quote
Old 01-29-2009, 03:32 PM   #7
Ferngrrl
yep, remove the wallpaper
As tedious as it may be, it's best to remove the wallpaper. Those steamers work nicely.
Depending on how old the wallpaper is and how well it was hung, eventually the seams will begin to show through the paint, especially on bathroom walls. This happened to me, and I'll never paint over wallpaper again!
Note: In othererooms, painting over wallpaper can lead to problems if, as in my previous house, the house eventually "settles" here and there. Then you get sagging and fold-looking wrinkles through the lovely paint job you did.
Ferngrrl is offline   Reply With Quote
Minimum wall thickness for electrical dc4nomore Electrical 10 10-10-2008 09:00 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 05:13 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
