Painting Over Vinyl Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 08:37 PM   #1
Rue
Painting over vinyl wallpaper
Is there a special process for painting over vinal wall paper?
Rue is offline   Reply With Quote
Old 07-21-2010, 08:42 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 850
Crossing you fingers and hoping for the best.
Sir MixAlot is offline   Reply With Quote
Old 07-21-2010, 08:46 PM   #3
Fixer upper guy
Rewards Points: 12
Remove the wall paper, then paint.
teg916 is offline   Reply With Quote
Old 07-21-2010, 10:23 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You will have better results if you remove the wallpaper and paint the walls.
housepaintingny is offline   Reply With Quote
Old 07-22-2010, 10:06 AM   #5
I have done this a couple of times. Just remember the paint job is only as good as the original wallpaper. I.e. you want to "fix" any aberrations in the wallpaper such as bubbles. Use a "high adhesion" primer first and then any good quality latex paint. I have used both latex primer and shellac based primer with success. Good luck.
cnicholas is offline   Reply With Quote
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 06:49 AM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 05:34 PM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
