Painting Over Vinyl Flooring - Painting - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 07:06 PM   #1
painting over vinyl flooring
thinking about using semi-gloss latex paint on my vinyl flooring and then polyurethane over that. Can that be done?
tfrantz is offline   Reply With Quote
Old 05-22-2012, 07:11 PM   #2
Framing Contractor
Rewards Points: 98
Can it be done? Yes.
Should it be done? Absolutely not. If the floor is that bad, it needs to be replaced.
sixeightten is offline   Reply With Quote
Old 05-22-2012, 07:13 PM   #3
Yes you can poly over paint. Although I'm not sure how well paint is going to adhere to a vinyl floor.
twostuds is offline   Reply With Quote
Old 05-22-2012, 09:37 PM   #4
Gymschu's Avatar
Rewards Points: 230
Less hassle, much cheaper in the long run to just replace.
Old 05-22-2012, 10:31 PM   #5
Too Short? Cut it Again!
If you must paint the vinyl, use something like Benjamin Moore's Floor and Patio acrylic product. It is epoxy reinforced. You could try the oil based alkyd product also. It is urethane reinforced. Both are excellent products. Both are self priming (not to be confused with primer and paint in one) and comes in many colors. I am sure Sherwin Williams and other real paint stores have similar products.
Don't use cheap box store paint, for anything but especially not for painting a floor or porch. The problem with semi-gloss is that it will not stick well to the vinyl without a primer and primers are not useful for floors. You would also have to let the semi-gloss cure for 30 days before putting the urethane on.
Adhesion of any paint to vinyl is going to be the real issue. If the floor is going to get any wear at all do not expect much from any paint. I painted the vinyl floor of an art gallery bathroom in a nice checkerboard pattern and custom colors. It has lasted five years or more and still looks nice. It gets very little foot traffic though and nothing gets dragged across it.
And add touch up painting it to your regular maintenance list if you paint vinyl. I guess if you are just trying to sell the place and the vinyl is just dated but in good shape painting it might be worth a try.
As hinted in an earlier post you might be better off just getting some new vinyl. It is not especially expensive and you may be able to pick up a remnant or roll end for chimp change.
Vinyl over Terrazzo Flooring in Bathroom? Amy Lou Flooring 0 02-15-2012 11:07 PM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 03:22 PM
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-05-2012 12:09 AM
Opinions on armstrong no-glue vinyl flooring thebestman36 Flooring 5 11-05-2008 06:18 PM
Ripping up Vinyl Flooring harmony Flooring 5 02-26-2008 05:50 PM
