Old 06-26-2012, 08:51 AM   #1
Painting over varnish
Is there a way to paint over varnish without having to sand the piece of furniture?
Shanklin is offline   Reply With Quote
Old 06-26-2012, 09:02 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Getting good adhesion is the most important part of paint over varnish. Dulling the varnish by sanding, and then using a GOOD bonding primer is more important than the finish coat . With out a good foundation, the paint will fail.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Mr. Paint (06-26-2012)
Old 06-26-2012, 01:00 PM   #3
ltd
yea ,you have to sand,wash first to remove lemon pledge or what ever .rinse clean ,dry,then lightly sand .i like 3m sand paper 180 grit.sand every inch.its not a big deal,really.remember your not making saw dust you are only deglossing.say a chest of draws 1 hour tops.oh yea we have systems in place to know if you did it or not
ltd is offline   Reply With Quote
Old 06-26-2012, 03:37 PM   #4
Mr. Paint's Avatar
"If you don't have time to do it right the first time, when will you have time to do it over?" John Wooden
Mr. Paint is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Cedar siding problem - Varnish flaking off - need solution memento Painting 3 07-15-2011 10:58 PM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Noob Painting Questions mark! Painting 6 12-09-2009 05:15 AM
Painting over varnish?? pickle13207 Painting 4 12-11-2007 09:50 PM
