Painting Over Trim - Painting - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 08:32 AM   #1
Painting over trim
Good morning,
I am planning to paint over trim which was previously painted. I had to repair some areas, the repairs are sanded. I plan to use semi-gloss, some shade of white. Is there a real advantage to prime the trim?
I will prime the wall. If I prime the trim, can I use the same primer for the trim at the same time?
wriegler is offline   Reply With Quote
Old 11-22-2010, 11:00 AM   #2
Hey Wriegler
The best way to look at most situations like yours is when in doubt throw a coat of primer on it. There are a number of reasons you donít want to pass on the primer. For starters, when applying most any paint over a semi-gloss you want to not only make sure itís clean but, to ensure the best adhesion of your new top coat lightly scuff sand it and primer it. Semi-gloss is ideal for use on trim, doors, furnitureÖect because of smooth shiny surface which lends to its ability to stay clean and repel stains, this isnít a great base for your paint which is why you need to prime. When doing any type of patch work it is a good idea to prime the areas you had reconstructed so that you finish with a consistent finish that wont flash or worse, peel later on down the road. Yes, just about every primer can be used from the walls to the trim, there are some specialty primers that wouldnít work but just make sure to read the labels. Good luck and hope it turns out nice.
Jeff
HDwetPaint is offline   Reply With Quote
Old 11-23-2010, 12:40 AM   #3
A Little Of Everything
Rewards Points: 1,356
Originally Posted by wriegler View Post
Good morning,
Prime it. Period.
You don't need a thick coat of primer, but you definitely need it or the paint won't adhere.
And yes, you can prime the trim and wall at the same time. Just don't glop in on thick.
DrHicks is offline   Reply With Quote
A couple questions (edging & trim painting) cellophane Painting 20 01-14-2010 06:23 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 03:57 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 08:00 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
