Painting Over Stained Wood Baseboard & Trim - Painting - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 07:29 PM   #1
Home Owner
Painting over stained wood baseboard & trim
Hey guys,
I'm interested in painting all the baseboards and trim in my home white. I personally like the look of the white trim vs the stained wood look.
What is the best method to cover the wood? Everything looks to be stain then lacquered.
I'm looking for a method that doesn't involve sanding the shine off
Can I just a purchase a primer, and paint on top?
Any suggestions or advice is appreciated.
Thanks!
Leenders is offline   Reply With Quote
Old 02-20-2011, 08:13 PM   #2
Super Master Painter
Ole34's Avatar
sand it down lightly with some 100 grit sand paper then prime it with Zinsser Cover Stain oil based and your good to go............I would thin the primer down with some paint thinner or penetrol to a consistency that's easy for you to handle rather then using it str8 from the can ........
Ole34 is offline   Reply With Quote
Old 02-21-2011, 06:49 AM   #3
Rewards Points: 101
I've done several jobs where the customer wanted stained trim painted. I first do a light sanding with some 120 to 150 grit sandpaper. Wipe sanding dust off with a clean rag. Then I prime with Glidden Professional (formerly ICI) Gripper.
This product has excellent adhesion and drys quickly. I've used this on stained trim and kitchen cabinets and had excellent results.
https://www.gliddenprofessional.com/...l_Task/Gripper
JMDPainting is offline   Reply With Quote
Old 02-21-2011, 07:25 AM   #4
Rewards Points: 252
you really don't have to use an oil based primer for this instance... Aqua Lock, zinsser 1-2-3 or 1-2-3 plus are all water based primers that would be a good choice. They are all designed to stick to glossy surfaces without sanding - although I agree with the previous posters that i would do a quick, light sanding first.. One coat of primer, one coat of a good quality trim paint..
mazzonetv is offline   Reply With Quote
Old 02-21-2011, 08:22 AM   #5
Home Owner
Perfect, that answers my question.
Thanks alot!
Old 02-23-2011, 08:36 AM   #6
bubbler's Avatar
Rewards Points: 256
I'm doing the same thing in my house, we have a mix of "medium" darkness stained trim and very dark trim.
This is what was recommended to us buy our carpenter and backed up by the manager (for what that's worth) at Sherman Williams:
1) Sand down w/ 80 or 100 grit
2) Wipe down with lacquer thinner
3) Paint w/ the SW "Adhesion" Primer (I believe it's ~$50/G, but it seems to go a long way as it's only being used on trim)
So far what we've noticed is that the adhesion primer seems to be off white when it dries. We've started to paint with some white gloss trim paint, and it's going ok, but does need a second coat to look right in some areas.
The SW guy claimed that the Adhesion primer does not require any sanding to stick.
bubbler is offline   Reply With Quote
Old 02-23-2011, 08:50 AM   #7
Coatings Nerd
Well, it doesnt, but it will be much better if you do sand lightly. You dont have to go crazy sanding, but a little bit is good. The bonding primers dont have much "hide" to them, so plan on 2 finish coats.
SW has some good products, and thats coming from a Benjamin Moore guy
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 01:27 PM
Help selecting wood to trim out interior windows and doorways RobertN Carpentry 11 01-07-2011 04:38 PM
Measuring trim for mitered baseboard installation abbyqueue Carpentry 3 07-28-2009 12:54 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
