Painting Over Stained Wood - Painting - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 08:34 PM   #1
painting over stained wood
Hi everyone,
I have a question I just finished staining just built bookcases.
I hate the color way to dark. My question is can I now paint
over this stain?
tombsgirl is offline   Reply With Quote
Old 09-18-2009, 10:10 PM   #2
Let the stain dry according to the stain directions. Then paint a small are to see if the stain bleeds thru. If it does use a stain blocker like Kilz, let dry, sand lightly with something close to 220 grit then paint. Another sure way to do it is let the stain dry, give it one coat with whatever clear you were going to use, let that dry, lightly sand it (same grit as above) then paint over. Bottom line is the stain needs to dry. The paint might seal in the stain, might not that's why you need to test the paint, no loss there. The clear or stain blocking primer like Kilz will seal the stain for sure. As far as lightly sanding (scuffing) you need to do that with paint, clear, primer or sealer. The reason for that is whatever finish you put on wood will raise the grain causing all your other top coats to feel and look rough. If you lightly sand after first coat the final coat will look a lot better. Good luck.
joegambler is offline   Reply With Quote
Old 09-23-2009, 11:56 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 614
You need to sand the wood first, scuffing it up, clean it with tsp, apply a good quality bonding primer, then you can top coat with a premium paint (enamel). Sherwin Williams has a great selection of bonding primers, ment to go over stained(varnished) surfaces.
housepaintingny is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Q about painting stained wood Corcoran1 Painting 4 03-27-2008 02:33 PM
