Painting Over Stained Wood - Painting - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 07:32 PM   #1
painting over stained wood
I want to paint over stained wood where do I look for directions?
dragracerske is offline   Reply With Quote
Old 01-09-2012, 07:41 PM   #2
Rewards Points: 13,740
It also most likly has a sealer on it. It's going to need to be sanded, wiped down with mineral spirits, primed with a bonding primer then painted.
Old 01-09-2012, 07:58 PM   #3
Rewards Points: 558
here you go, read up: http://www.ehow.com/how_5422493_pain...ood-stain.html or look at some youtube video's: http://ca.video.search.yahoo.com/sea...od&b=19&tnr=18
epson is offline   Reply With Quote
Old 01-10-2012, 07:04 AM   #4
ARC Painting's Avatar
depends on the condition of sealer/finish. this determines how much "grab" youll need for paint to stick.
i.e. priming almost certainly, some sanding likely...
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 01-11-2012, 04:58 PM   #5
JoeCaption hit it on the head. Sure it wouldn't look nicer with a nice restain? In most cases, people only stain something if the wood is a good quality. Sometimes it's not worth it painting over something that can look so good stained.
metal is offline   Reply With Quote
Old 01-11-2012, 05:15 PM   #6
I don't like the idea of wiping the surface with thinner if you are planning to use a latex primer. Thinner will leave an oily residue on the surface which may create adhesion problems.
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (01-11-2012)
Painting over wood furniture woody1 Painting 8 05-19-2013 10:23 PM
Painting a bright wood stand to a darker color seavash Painting 1 07-24-2011 09:17 AM
Painting wood bed frame that has been stained JamesTee Painting 3 03-14-2011 11:32 PM
Painting over stained wood baseboard & trim Leenders Painting 6 02-23-2011 08:50 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
