Painting Over Stained Oak Wood - Painting - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 07:54 PM   #1
Painting over stained oak wood
What is the best way to cover stained wood. Do you have to sand first? Are there any new products that make this easier?
cdkessinger is offline   Reply With Quote
Old 03-29-2012, 09:09 PM   #2
Rewards Points: 14,300
Clean it, sand, clean again, bonding primer, then two coats of paint.
Old 03-29-2012, 09:28 PM   #3
Rewards Points: 258
You might want to take a closer look at the wood, it looks very much like a laminate. Can you run your finger nail across the surface and feel the grain or is it smooth? If it’s smooth then it’s not wood. Either way Joe is giving you good advise for either.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 03-30-2012, 12:26 PM   #4
Too Short? Cut it Again!
Hold the phone!
If it is laminate it is, at the end of the day, plastic fantastic. You will need something like a plastic primer (Rustoleum brand plastic primer comes to mind. It comes in liquid and rattle cans and you can paint over it with anything reasonable) or rattle cans of paint just for plastic like Krylon Fusion.
You might get a real paint store melamine paint to stick. Conventional primer, even high bond, and subsequent finish will not work. They are not formulated to adhere to a laminate or plastic surface. And I would not bet on the plastic primer or paints lasting as long as you might like without flaking off.
Old 03-30-2012, 02:37 PM   #5
Rewards Points: 258
I believe this is what joe had in mind.
Information Disclaimer
400W White: Product Number 1102 Solvent Born, Bonding Primer Sealer, VOC: less than 495 g/l • Properties of both a primer and an adhesive • Makes paint stick to tough-to-paint surfaces, including ceramic tile, porcelain, glass, Formica and melamine laminates, PVC, fiberglass, many plastics, aluminum, many metals, wood • Very fast drying • Tintable to pastel colors with universal tint colors • Interior / Exterior applications • Top coat with oil-alkyds and latexes in 60 minutes
Best of Luck
Steve
Painting a bright wood stand to a darker color seavash Painting 1 07-24-2011 09:17 AM
Painting wood bed frame that has been stained JamesTee Painting 3 03-14-2011 11:32 PM
Hardwood Color in Home with stained wood trim mammaof4 Flooring 1 03-14-2011 08:23 AM
Painting over stained wood baseboard & trim Leenders Painting 6 02-23-2011 08:50 AM
Fullview storm door with stained wood front door matjam68 Remodeling 1 05-06-2010 06:18 AM
