-   -   Painting over stained oak wood (http://www.diychatroom.com/f4/painting-over-stained-oak-wood-138688/)
cdkessinger 03-29-2012 07:54 PM
What is the best way to cover stained wood. Do you have to sand first? Are there any new products that make this easier?
joecaption 03-29-2012 09:09 PM
Clean it, sand, clean again, bonding primer, then two coats of paint.
spraygunn 03-29-2012 09:28 PM
You might want to take a closer look at the wood, it looks very much like a laminate. Can you run your finger nail across the surface and feel the grain or is it smooth? If it’s smooth then it’s not wood. Either way Joe is giving you good advise for either.
user1007 03-30-2012 12:26 PM
Hold the phone!:no::no::no:
If it is laminate it is, at the end of the day, plastic fantastic. You will need something like a plastic primer (Rustoleum brand plastic primer comes to mind. It comes in liquid and rattle cans and you can paint over it with anything reasonable) or rattle cans of paint just for plastic like Krylon Fusion.
You might get a real paint store melamine paint to stick. Conventional primer, even high bond, and subsequent finish will not work. They are not formulated to adhere to a laminate or plastic surface. And I would not bet on the plastic primer or paints lasting as long as you might like without flaking off. :thumbsup:
spraygunn 03-30-2012 02:37 PM
I believe this is what joe had in mind.
http://www.ximbonder.com/upload/item...b%20300dpi.jpg
Information Disclaimer http://www.ximbonder.com/images/spacer.gif
400W White: Product Number 1102 Solvent Born, Bonding Primer Sealer, VOC: less than 495 g/l • Properties of both a primer and an adhesive • Makes paint stick to tough-to-paint surfaces, including ceramic tile, porcelain, glass, Formica and melamine laminates, PVC, fiberglass, many plastics, aluminum, many metals, wood • Very fast drying • Tintable to pastel colors with universal tint colors • Interior / Exterior applications • Top coat with oil-alkyds and latexes in 60 minutes
