Old 03-24-2007, 06:35 PM   #1
Painting over stain
Can you paint over wood that has been stained without sanding or stripping? thanks.
econdave is offline   Reply With Quote
Old 03-24-2007, 06:51 PM   #2
Pro Painter
Painting over stain
There isn't a black and white answer for that.
Stained wood is always covered with a clear coat that is very smooth. A smooth finish does not promote paint adhesion. So, simply put, you can paint it, but chances are that the paint will not last very long, or it won't stick very long.
There are primers that advertise being able to go right over stained wood without sanding. However, as a painter, I would always, always recommend sanding and priming.
There's good news. Sanding this type of finish isn't very difficult. It's more of a scuffing than a sanding, just enough to remove the shiny finish.
Stripping won't be necessary.
joewho is offline   Reply With Quote
Old 03-24-2007, 07:21 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Painting over stain
The proper way would be to lightly sand and use a solvent based primer
slickshift is offline   Reply With Quote
Old 03-24-2007, 07:31 PM   #4
Painting over stain
I doesnt appear to have a shiny finish, very dull actually. I dont think there is a clear coat or poly on the door I want to paint. So can I just prime and paint?
Old 03-24-2007, 08:53 PM   #5
slickshift's Avatar
Painting over stain
It's just stain then-no poly
Very common
You still should do a light "scuff" sand and wipe it clean (of any dust) with a tack cloth before priming
I'd clean it first too
There's probably dirt and oils from hands on it
Use whatever cleaner the solvent-based primer of your choice says to use on the can
Or ask at the Paint Store where you get your primer
Old 03-30-2007, 10:09 PM   #6
remodeling pro
Painting over stain
Without stripping, yes. Without sanding and priming , not if you want the paint job to last.
troubleseeker is offline   Reply With Quote
Rust stain on roof krtw Roofing 12 10-20-2012 01:57 PM
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
painting over a wood stain franko24 Painting 5 10-13-2010 08:52 PM
Exterior Door Painting vs. Stain paradis42 General Discussion 1 11-12-2005 11:57 AM
