Old 01-20-2009, 02:47 PM   #1
Painting over stain
I have tp paint 2 wood doors that are currently stained. any tips?
beerdog is offline   Reply With Quote
Old 01-20-2009, 04:07 PM   #2
Painting over stain
Have the doors been varnished, or only stained. If they've been varnished, would you have any guess as to how long ago they were varnished?
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-20-2009, 04:41 PM   #3
bradnailer's Avatar
Painting over stain
Use one of those really expensive roller covers. Just kiddin.
If they've been poly'd then it seems to me that you'll need to lightly sand them, then either prime them and finish with latex or use a good enamal. Latex on top of poly will never hold up.
bradnailer is offline   Reply With Quote
Old 01-20-2009, 05:18 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Painting over stain
Clean
A light scuff sanding
Wipe off dust (tack cloth is a good choice)
Prime with a quality oil-based primer (Zinsser's Cover-Stain is a good choice)
Lightly sand and tack again
Two coats premium quality enamel (Ben Moore's Satin Impervo or Sherwin William's Pro Classic are good choices), oil or waterborne (your choice)
slickshift is offline   Reply With Quote
Old 01-21-2009, 11:52 AM   #5
Matthewt1970's Avatar
Painting over stain
Originally Posted by slickshift View Post
Clean
Exactly.
Old 01-21-2009, 12:06 PM   #6
Painting over stain
Well, the reason why I asked the questions I did is:
A) If the doors have been stained, but never varnished, then he could primer right over the stained wood, and
B) If the doors were varnished prior to 1956 (when oil based polyurethane first came out), then instead of sanding, he could use TSP to dull the gloss of his real varnish rather than sand.
painting over a wood stain franko24 Painting 5 10-13-2010 08:52 PM
Painting over stain econdave Painting 5 03-30-2007 10:09 PM
Exterior Door Painting vs. Stain paradis42 General Discussion 1 11-12-2005 11:57 AM
