Old 03-15-2008, 11:25 PM   #1
Painting over a sponge painted wall
Hello all,
While I am not new to painting I am new to the new techniques of painting. My wife and I are closing on our first house next month. Our problem is the present owners painted the living room a light pink base with a dark pink sponge technique. Looking at the walls they are no large ridges but I can see a slight height difference in the paints and am worried about these patterns showing through after priming and painting. Has anyone painted over walls with this treatment and was there a noticable pattern if you didn't sand? I would rather not sand if possible but want to do this painting once and not have to worry for many years.
Snowdog is offline   Reply With Quote
Old 03-16-2008, 08:24 AM   #2
paper hanger and painter
chrisn's Avatar
Sand off the ridges, prime and paint.
Old 03-16-2008, 08:26 AM   #3
Paint does a horrible job of hiding texture defects. I would not try to "get away" with not smoothing if I were in your place.
There are three options:
1) Sanding. Use of a "drywall screen" could work here.
2) Skim coating with an extremely thin coat of joint compound; which is then sanded and primed.
3) Hi-build primer, which is then sanded.
SirWired
sirwired is offline   Reply With Quote
Old 03-17-2008, 12:13 AM   #4
Thanks guys, I definately don't want to take to much of a shortcut. I'll sand then prime and paint. I was going to use the drywall screen as I thought it would last longer than sandpaper.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
painted concrete under the wall paper? guygood Painting 3 12-01-2007 12:57 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Wall Patching Shows Through After Painting wcw5961 Painting 5 11-16-2006 06:33 PM
