Painting Over Silicone Caulk?? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 10:05 PM   #31
Painting Contractor CT
Rewards Points: 77
Post
Painting over silicone caulk??
You can either caulk over it and then paint or remove the silicone, caulk and paint.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-14-2013, 10:16 PM   #32
Carpenter/Rehabber
moorewarner's Avatar
Originally Posted by ccarlisle View Post
In actual fact, that silicone adhesive your friend inadvertently used is a fine example of just how silicones work - well, that is those that are chemically of a certain structure (because not all silicones show adhesive proeprties - but close enough for the sake of this thread).
Silicones like this one attach themselves chemically to the substrate whereas other caulking compounds attach themselves mechanically to the substate. In doing so, silicones can attach themselves to pretty well any substrate much better than other products because they orient themselves in such a way that on one side of the bead (towards the substrate) they stick and on the other side facing you they do the opposite: they repel anything that tries to stick to them...
Chemical bonding and all that...but on the side facing you, you are looking at a very slick surface that as I said repels everything - much like the wax on the hood of your car...products just bead up once they land on a silicone and fall off. They do that by orienting the silicone molecules in such a way that the surface has very low "surface tension". That means everything rolls off it.
To put it into numbers, the silicone surface has a surafce tension somewhere around 30 dynes/cm...water has a higher surface tension around 72 dynes/cm. Now by physiochemical principles, the higher surface tension product (water) cannot remain comfortably on the lower surface tension product (silicone) - and the water rolls off.
Thus the only way to make something stick to a silicone is to give it the same surface tension as the silicone...don't ask how I know that, I just do.
Ta-da... "fluorochemicals" to the rescue!!
If you put "fluorochemicals" into a caulk or a paint, it would stick to silicones. Some products have "fluorochemicals" in them, but they ain't cheap.
Sooooo...95% of the products you try to put over that type of silicone wan't stick for very long. But one or two just might. Either spend your time trying to find that one or two products, or take it out and do it properly.
Here endeth the lesson... Not bad for a Saturday night I gotta get a life...
Am I the only one who's nipples got hard reading that?
moorewarner is offline   Reply With Quote
Old 06-14-2013, 10:18 PM   #33
Carpenter/Rehabber
Good Luck!
I was going to suggest/ask about this solution. Do you know it to work? Does it work well?
Old 06-14-2013, 10:18 PM   #34
Rubbin walls since'79
Brushjockey's Avatar
I think I had a little stiffy myself..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
moorewarner (06-14-2013)
Old 06-15-2013, 05:33 AM   #35
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
carlise quotes this( along with a lot of other stuff) ( good stuff)
"Some products have "fluorochemicals" in them, but they ain't cheap. "
got any names?
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
silicone on silicone caulk ponch37300 Kitchen & Bath Remodeling 2 05-09-2009 09:11 AM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 09:03 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
