Painting Over Semi Gloss Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 05:16 PM   #1
painting over semi gloss paint
I am covering semi gloss painted wall with a flat finish paint.my question is how do I cover it do i have to put a primer,scuff or go over the whole wall with sand paper( to scuff it up) or can I just paint the wall with the new paint?the wall is painted a semi gloss gray and i am trying to put the same color gray on the wall with a flat finish
ckr31 is offline   Reply With Quote
Old 10-09-2010, 10:03 PM   #2
just go right over it.
primers biggest use is with either dirty scuffed up paint or drastic color changes. if you paint white over orange you'll want primer. orange over white, not needed. in your case grey over grey is easy and your paint will cover very quickly. if you rush you can still get 30% off at sherwin williams, the sale is over oct 10th. this puts classic 99 at a lower cost than even the big box stores.
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
KrazyCoyoteKim (10-04-2011)
Old 10-10-2010, 07:20 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
If I was doing it,I would scruff up the semi gloss paint first and make sure it was clean before attempting to put another coat of paint on there.
Old 10-10-2010, 08:43 AM   #4
Someone went over semi-gloss here on the trim
It peels off quite easily
Made it easier to strip the paint to re-paint
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Painting over unknown paint? Randall53 Painting 4 09-07-2009 04:40 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Priming "builders grade" paint before painting Plasmech Painting 10 03-30-2008 01:37 PM
