Painting Over Semi-Gloss Paint - Painting - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 06:29 PM   #1
diy'er
la15ota's Avatar
Painting over Semi-Gloss Paint
I'm off to paint our laundry room now.
The walls are textured with the lovely orange peel, so sanding all the crevices is impossible. There's no issue with moisture buildup.
Is there any prep work that is necessary to paint over semi-gloss?
Do I need a primer?
I plan on using Benjamin Moore - Aura or Natura paint lines again, since they both worked out so well in my son's bed room.
la15ota is offline   Reply With Quote
Old 06-11-2009, 06:42 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Make sure to clean it as best you can and paint away
Old 06-11-2009, 09:39 AM   #3
100 Year Family Tradition
4ThGeneration's Avatar
Do I need a primer?
Always a fan of the generic gimmie:
Dull, Clean and dry, but orange peel would be a pain to sand. You can scuff over the tops of it, but it will not sand all the nooks and such.
I always hear the aura and the better paints are self priming, but when going over a semigloss may be a bit different. Is the semigloss you are talking about in the kitchen or bathroom. If so you will need to clean it first to remove dirt, mold, algae and oils.
also, is the semigloss a oil based or latex based. That will help further in your quest for an answer.
4ThGeneration is offline   Reply With Quote
Old 06-11-2009, 01:32 PM   #4
diy'er
la15ota's Avatar
Upstairs laundry room, I plan on using the vacuum to dust of the walls.
Original paint is a latex semi-gloss
Old 06-11-2009, 05:50 PM   #5
Vacuum will only do so much. Never tried it, but use a dry swiffer to get rid of the dust. Also, get your dryer ducts cleaned for less dust future. If you use a top of the line BM or SW you should be fine.
Old 06-11-2009, 06:21 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
..ayup..
slickshift is offline   Reply With Quote
Old 06-11-2009, 06:59 PM   #7
diy'er
la15ota's Avatar
okie dokie...thanks everyone
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
