Painting Over Semi-gloss - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 06:03 PM   #1
Painting over semi-gloss
I made the mistake of painting a satin paint over semi-gloss. Of course it isn't sticking well. Can I just prime over the paint I have on the wall now or do I need to sand over the entire thing?
Thanks!
turtleescape is offline   Reply With Quote
Old 08-07-2010, 08:15 AM   #2
Thanks!
You need to get down to a sound substrate. (sand, strip, scrape)
hennyh is offline   Reply With Quote
Old 08-07-2010, 10:06 AM   #3
Rewards Points: 558
Yup what you did was use a water base paint on an oil base and thatís why you have a problem. Now you have to remove the paint by sanding and cleaning your walls with TSP you can find this at any paint or home center. After sanded and cleaned your wall(s) use a oil base primer and you can either apply a water base or oil base finish coat over it with no problems...
epson is offline   Reply With Quote
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
painting over semi gloss on walls? MHG Painting 3 01-10-2009 02:46 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
semi gloss sheen problems Pawl Painting 5 03-15-2008 10:29 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
