Painting Over Semi-gloss - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 12:24 AM   #1
Painting over semi-gloss
I have old walls in my house that have been painted with paint containing lead by the previous owners. When we moved in we had the walls repainted but the workmen accidentally painted a semi-gloss over the primer. Because of the lead I cannot scrape the walls and repaint without making a lead dust cloud. Any suggestions to repaint the walls?
musicrox1210 is offline   Reply With Quote
Old 07-19-2012, 02:20 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
When was the house painted with the supposed lead paint? It has been banned since the 70's
Anyway, prime with Zinnsers Cover Stain, or Bullseye 123 first.
Old 07-19-2012, 07:08 AM   #3
Too Short? Cut it Again!
You should be able to scruff up the semi-gloss a bit with fine grit paper without hurting anything with lead under that layer. You want some tooth to the semi-gloss to improve adhesion although a bonding primer should do the trick.
Old 07-19-2012, 08:25 AM   #4
A Little Of Everything
Rewards Points: 1,364
That was my first thought. If the most recent coat of paint contains lead, it has been a LONG time since any work has been done in that house!
DrHicks is offline   Reply With Quote
Old 07-19-2012, 09:20 AM   #5
Phil - "the Paint Guy"
Use a lead test kit available at your local paint store. Swab the surface if it's red then you have lead. Like the other posts I would find it hard to believe that you would have paint with lead in it. It would be really old.
If you discover there's no lead make sure the surface is clean, dull and dry then paint.
Cpcphil is offline   Reply With Quote
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
painting over semi gloss paint ckr31 Painting 3 10-10-2010 08:43 AM
painting over semi gloss on walls? MHG Painting 3 01-10-2009 02:46 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
