Painting Over Repaired Areas On Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 03:39 PM   #1
painting over repaired areas on drywall
I have areas on my walls that were spackle patched and then a sealer was used on the patched areas before they could get sanded is there a way to fix this?
sandymc is offline   Reply With Quote
Old 08-22-2011, 04:03 PM   #2
Who did that? Sanding primed patches is a bit difficult. If they're really rough you can take some 60 or 80 grit paper, sand the heavy stuff out and then skim coat them smooth. Or, you can just skim coat them if they're not too rough.
Old 08-22-2011, 04:10 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Agree. Use a solid hand sander, not a sanding sponge to get it flat. A sponge will just round it off. Actually shouldn't be too hard to correct. But I see this mistake done by homeowners all the time.
Brushjockey is offline   Reply With Quote
Old 08-22-2011, 04:20 PM   #4
sandymc
WELL HER DADDY IS ONE OF THOSE, " GIT-R-DONE" KIND OF GUYS AND KNOW LITTLE ABOUT REPAIRING AND PAINTING WALLS. HE'S MORE INTO BUILDING BIRDHOUSES AND CHICKEN HOUSES......NEED I SAY MORE?????
ANY WAY THANKS ALOT FOR YOUR HELP
Painting over exposed Drywall Metal Heartwoode Painting 2 02-22-2011 08:40 AM
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 07:51 PM
Painting over a drywall disaster picsaro Drywall & Plaster 15 01-07-2009 09:56 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
Painting drywall in garage Rod Painting 5 08-12-2005 06:36 PM
