Old 09-19-2008, 02:51 PM   #1
Painting over red walls
Hi all: I'm repainting a small deep red bathroom (took me 6 coats, wish I came here first to find out about tinting the primer) and I'm wondering if instead of using kilz or some other such primer, can I use left over paint? I've got various shades of light green and yellow, it's behr and benjamin moore, about 2 years old, has been stored properly and the consistency looks fine.
I hate to just dump this no longer needed paint, not to mention buying primer when I might not need it.
thanks
mary
keishoos is offline   Reply With Quote
Old 09-19-2008, 03:01 PM   #2
Matthewt1970's Avatar
Absolutely. I do that all the time but it would depend on what color you are going to end up with as a finish coat. Sometimes you can make your job harder if you put an even stranger color on the walls and then try to cover that with a finish color. The Benjamin moore is what I would use first. What color do you want to end up with ?
Matthewt1970 is online now   Reply With Quote
Old 09-19-2008, 03:10 PM   #3
Hi: I'm probably going to paint it a light tan color, or something off white - not dark, though. I should point out the paint smells ok, too - I've opened old paint that's gone rancid, and know the difference.
Also, from what I've read, I gather I should lightly sand the walls before I put anything on it?
thanks
How to remove adhesive from painted walls before painting buffnrie Painting 3 04-27-2008 02:14 AM
Painting walls different color at an outside corner J187 Painting 8 08-16-2006 08:16 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 03:28 PM
