Old 06-16-2009, 08:07 AM   #1
Painting over Polyurethane?
I applied poly over white kitchen cabinets and they are starting to turn yellow. Could I paint over them? If so, what kind of paint should I use?
tate16t is offline   Reply With Quote
Old 06-16-2009, 08:13 AM   #2
the Musigician
DangerMouse's Avatar
oil-based for kitchens is most recommended.... de-grease with TSP or a mixture of Dawn for dishes and water, then lightly sand, wipe clean and apply paint. oil-based for primer and paint....
of course, i could be wrong now..... but i don't think so.....
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-16-2009, 11:01 AM   #3
If you are going to paint white than I would use a water based topcoat like ben moores waterborne Satin Impervo, or Cabinet Coat, or a similar product. White Oil based paints will turn yellow, especially in a kitchen over time. The water based whites will stay a brighter white. Most of the times you don't even realize they are yellowing, however if you have white appliances they stick out like a sore thumb. Ditto the previous comments on cleaning and priming first - can't go wrong with an oil based primer - could get away with using 1-2-3 or a similar bonding primer.
Good luck!!!
mazzonetv is offline   Reply With Quote
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 09:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
Painting over polyurethane coated wood doors flashme18 Painting 9 04-19-2008 10:51 PM
