Painting Over Patchy Paint/plaster - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 08:25 AM   #1
melaniec's Avatar
Painting over patchy paint/plaster
Hiya, am doing first round of diy, have stripped wallpaper off and result is as attached photo - some paint underneath has come away with the paper leaving a patchy wall where plaster showing through.The remaining paint wont come off. Need to paint this wall without it showing through. All ideas welcomed except cant afford to plaster!
Painting over patchy paint/plaster-image-777130605.jpg
melaniec is offline   Reply With Quote
Old 05-05-2013, 08:27 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Read this thread a couple down from yours- might answer you q's.
http://www.diychatroom.com/f4/removing-wallpaper-then-painting-question-176602/
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-05-2013, 09:50 AM   #3
melaniec's Avatar
Thanks, So i use gardz? On just the bare plaster area or the whole wall as the remaining white paint will not come off , have scraped and sanded to no avail. Am worried about patches showing through final painting. .
Old 05-05-2013, 09:53 AM   #4
Using Gardz will be a little like hitting reset- it will seal the surface and give you a new starting point. It is a real problem solver. But it is clear- so it won't be easy to see what might need skimming.
Old 05-05-2013, 09:55 AM   #5
It is not the bare plaster that is showing through, but an earlier coat of paint.
If it were me, I'd give the walls a light skim after the gardz. But that is not so easy for a first time DIY. But it probably is what it needs.
Then sand smooth, reprime with a pigmented primer, and finish.
The Following User Says Thank You to Brushjockey For This Useful Post:
user1007 (05-05-2013)
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 08:50 PM
painting my mom house supaflyz Painting 5 07-28-2009 03:34 PM
