-   -   Painting over panelling - seek advice (http://www.diychatroom.com/f4/painting-over-panelling-seek-advice-3328/)
deb14905 08-05-2006 09:11 AM
I am a new member and this is my first post.. I have a basement with dark panelling and seek advice. I was going to see about having someone remove the panelling, and put up drywall and paint it but several men who looked at the job said that it would be easier to just paint over the panelling.... the problem is, I don't really like all the grooves between the lines..... I was wondering about using wallpaper liner and then painting over that...... or is there some other product that anyone recommends to use over panelling to cover up the grooves and smooth it out and then paint over it??? I appreciate any advice
deb14905
slickshift 08-05-2006 02:07 PM
What has worked or me in the past is:
Scuff sanding the paneling
Priming with BIN (shellac-based primer)
Smoothing joint compound (drywaller's "mud") into the cracks with (drywall) taper's knife
Sanding to smooth, (re)priming the repair areas with a regular primer
Painting with two coats quality latex paint
deb14905 08-05-2006 03:37 PM
scuff sanding?
I am the one who posted the message... thanks for the advice... what do you mean by scuff sanding???
lxdollarsxl 08-05-2006 08:42 PM
Ive done a few nearly the way slick suggested, i found it a lot of work - i guess there is drywall or similar beneath the panelling, i would find someone to remove it and skim the surface, a good tradesman wouldnt need to do a lot of finishing, then its off to prime and paint.
slickshift 08-05-2006 09:00 PM
A light sanding
Not sanding to remove the finish, but "scuffing up" the surface to give the primer some "tooth", or help adhering
deb14905 08-10-2006 01:15 PM
Sanding Panelling before Painting it
Originally Posted by slickshift
A light sanding
When I sand the panelling, what kind of grit of sandpaper would I use?
deb14905
slickshift 08-10-2006 08:37 PM
180 would be the best bet
AtlanticWBConst. 08-11-2006 10:44 AM
Agree 100 Percent with Slickshift's method. We did the same in a foyer area. When done (And done right) It is hard to tell that it is not drywall.
deb14905 08-11-2006 11:05 AM
painting over panelling - thanks
Thanks for those who posted replies to my inquiry about painting over panelling. I am a newbie and need all the help I can get..
deb14905
deb14905 08-15-2006 10:37 AM
Re. BIN --- is this the oil based BIN or latex BIN that I should use???
slickshift 08-15-2006 05:03 PM
Oooh, neither
The "white-pigmented shellac-based" BIN
It might be considered a "solvent-based", but so is oil-based product
You want the shellac-based
http://www.zinsser.com/images/binprimer.jpg
(image courtesy of Zinsser)
slickshift 08-15-2006 05:06 PM
... I should add that it is quite stinky when wet and curing and proper care should be taken
Some open windows and a respirator would be good
It dries super-fast though
Piney 10-13-2006 08:17 PM
Greetings--
Soooooo-- are you folks saying to float the ridges in the panneling AND to float and tape the joints bewteen sheets, just as one would do on drywall ?
THanks--
slickshift 10-13-2006 08:26 PM
I don't believe anyone mentioned taping the joints
