Painting Over Paneling - Painting - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 02:59 PM   #1
painting over paneling
How do you paint over old outdated paneling ? That's from nineteen hundered and seventy three.
I have been told that it can be done but takes extra steps & procedures.
joshl is offline   Reply With Quote
Old 01-01-2012, 03:06 PM   #2
Rewards Points: 14,000
If you want to end up with a wall that looks like cheap painted paneling then just clean it, prime with a bonding primer then paint.
Old 01-01-2012, 03:07 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depends on if it is Masonite panelling or wood panelling. Need to know.
XXX
Old 01-01-2012, 04:34 PM   #4
About painting over paneling
Hello again
This is wood paneling from 1973
joshl
Old 01-01-2012, 06:16 PM   #5
ARC Painting's Avatar
Prime for adhesion, since it is likely has some kind of clear finish. if its really glossy, might want to scuff sand first.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
The Following User Says Thank You to ARC Painting For This Useful Post:
DrHicks (01-01-2012)
Old 01-01-2012, 06:20 PM   #6
We used a product called Kilz primer. Then painted with the paint of choice. It worked and has held up well. However, the paint of choice was a flat finish not my preference.
Mr. B is offline   Reply With Quote
Old 01-01-2012, 06:24 PM   #7
A Little Of Everything
Rewards Points: 1,364
Painted paneling can look just fine, but there will never be any question what it is. Good quality, well applied primer is going to be extremely important.
When I've painted paneling I've been very careful to brush the grooves well, then roll the flat surface. It takes a lot of extra time, but will turn out just fine.
By the way, why are you using that huge green font?
DrHicks is offline   Reply With Quote
Old 01-01-2012, 07:23 PM   #8
Hello Again
Thank-you for your reply
I did ask for this advice but I expected to hear , fill in the verticle lines with a putty or some kind of wood filler ?
The reason for the font is #1 it easier to see what I write verses what someone else writes and it's easier to read, I also like the colored letter.
But I have not found where the spell correction is, but there seems to be a misspelled identifier here ?
joshl
Old 01-01-2012, 08:03 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
If you're trying to make the paneling look like a flat wall- you probably won't. Remove and put up a thin 1/4 " sheetrock and finish .
But if you want to have painted paneling, do as suggested-
Scuff sand ( knock down the gloss so the primer can get a better grip)
Prime with an adhesion primer ( zin 123, Smart Prime are good choices)
You will have nail holes you didn't see and some caulking to do after prime.
Then finish with at least an eggshell finish. I often apply with a roller and then strike off with a brush to fill the grooves and give it more of an enameled trim look.
Here is one I did- paneling one color- trim another-BTW this was VERY dark panelling to begin with. Prime with smart prime and 2 coats Aura
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-01-2012, 08:54 PM   #10
Hello Brushjockey
Thank-you for the advice and a good example.
Would it be advisable to caulk the obvious
nail holes / injuries to the paneling, before I do the scuff & sand ?
And the verticle lines in the paneling will get filled in with the Zin 123 / premium primer ?
Should I use a belt sander or what to do the sanding
joshl
Old 01-01-2012, 09:01 PM   #11
Please use regular size font- it looks like you are so very much more important...
The sanding does not have to be deep, just all over . I use a Med sponge sander. Just trying to break the gloss.
Then prime. It will then be obvious what needs filled.
The grooves will not go away. It is possible to fill them, but it usually is not worth it. Like I said, if you expect it to look like a regular flat wall, it won't .
It will look like painted paneling. Not a bad thing, but it is what it is.
Old 01-01-2012, 09:55 PM   #12
Hello Arc painting
Do I need to use a belt sander or what to do the sanding , I have heard to use a premium primer though
joshl
Old 01-01-2012, 10:01 PM   #13
Post
I would just use a pole sander or hand sander with 80 or 120 grit, and give it a once over, no power sander needed. You are just scuffing, not removing the finish.
If it isnt too glossy you could just prime with a premium primer. Depends on how glossy it is.
Old 01-01-2012, 10:13 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
joshl,
You don't seem to get it and you are headed for trouble.
Why not remove the paneling and repair any damage and paint what is left?
XXX
Old 01-02-2012, 06:34 AM   #15
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can paint over some paneling, dependent also on how it is secured (not loose).
In some situations, Home Owners want a quick and temporary improvement. Some paneling has been installed with adhesives that will damage the underlying substrate (which is usually sheetrock) - when removed and creates more work (that may not be at the skill-level of the DIYer to handle such on their own - in an expediant manner).
Again, I would not label or consider it a a permanant soluation, however, I would consider it a temporary and cost effective improvement for some people (not for others).
Would I do it in my own home? I did it in my first house (for the reasons that I listed above) and was very pleased with the outcome, even after 10+ years that I lived there. Not one house guest ever had any idea that there was panelling on that particular room's walls. I've sinced moved.
As stated: Clean the paneling, re-nail & caulk the seams, and treat it with oil-based Kilz or Binz. Later, apply seam tape over joints, and drywall compound over the channels and again over the seams. Coat and sand smooth (just like drywall). Prime & Paint.
It works if it is done right and can hold up for a surprising length of time.
Good Luck.
- Build Well -
Painting Over Paneling: Primer Recommendation michaelcherr Painting 2 10-04-2011 08:19 PM
Wall paneling keeps bleeding after painting Ronnie Herndon Painting 3 10-04-2010 06:44 AM
painting paneling with a sprayer? b_corwin Painting 2 10-04-2009 08:28 AM
Painting Over Wood Paneling vomtickie Painting 8 08-01-2007 04:07 PM
Painting Paneling - Do I need deglosser? sweetsue777 Painting 7 01-30-2007 01:35 AM
