-   -   Painting over painted exterior brick (http://www.diychatroom.com/f4/painting-over-painted-exterior-brick-14624/)
kbrooke 12-20-2007 11:04 AM
What is the best method to paint over exterior brick paint. My exterior brick has been painted and it needs repainting. Do I just power wash and paint away? Is there specific paint that should be used.:mad:
troubleseeker 12-26-2007 07:55 PM
If the existing paint is still holding ok, you should be able to power wash and repaint. Chances are the power washing is going to knock a few spots off, so be prepared to spot prime a little. If the old paint is chalking, it is best to reprime before painting or the new paint will not adhere very well. Best advice is to go to a real paint store, like Benjamin Moore or Sherwin Williams, and follow their advice. Stay away from Home Depot and Lowes paint dept.
chrisn 12-27-2007 06:10 AM
Good advice:yes: :yes:
GreenContractor 01-01-2008 10:39 PM
behr might make it a year with out flaking off on the exterior, great advise to use the same paint professionals use.
housepaintingny 07-25-2009 10:31 PM
I agree, stay away from home depot and lowes. There employees are not properly trained. I am a professional painting contractor in NY. Power wash the surface, clean with tsp, scrape any loose paint, let surface dry, prime with a masonry primer that's 100% acrylic, and apply two top coats of a paint that's 100% acrylic. I would prime with a100 from sherwin williams and top coat with super paint from sherwin williams,we use both products on a regular basis and have never had a problem, they can also both be used on masonry and we do use them on masonry.
chrisn 07-26-2009 05:42 AM
clean with tsp
You clean the WHOLE house with TSP??:eek:
housepaintingny 07-26-2009 06:48 AM
Originally Posted by chrisn (Post 306835)
clean with tsp
Liquid concentrated tsp. The liquid concentrated tsp is mixed with Water in a pump sprayer and sprayed onto the substrate and rinsed off with a pressure washer
chrisn 07-27-2009 04:06 AM
Never heard of that but will look into it.thanks.
housepaintingny 07-27-2009 06:12 AM
Welcome, we use it often in that form. Its in a 16oz bottle and that one bottle will make a couple of gallons after its mixed with water, then we spray it on, brush it if needed, then power wash it off.
4ThGeneration 07-27-2009 09:27 PM
If you have a low GPM home depot type of pw you probably will not get allo the TSP off and it will etch your windows. Beware...
