Painting Over Mold, Best Thing To Do? - Painting - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 10:37 PM   #1
Painting Over Mold, Best thing to do?
So my washroom seems to build up mold continuously , From all the steam and dust. ugh, fine.
But It's starting to build up and it's very annoying for a very long time(years). I know it's not good for your health for obvious reasons.
How should I approach this, shall I try and clean it with vinegar, bleach? still dosen't work so well anyhow. I'm in the process of painting over it. But I'm still trying to decide whether cleaning it properly and layering it with paint will keep away the mold. besides keeping the fan on after a steamy shower and wipe down wet surfaces.
See it might be the old washroom ceilings and walls that are filled with mold inside the drywall/wall itself since I own my home its more expensive and I couldn't afford too renovate my home.
Any suggestions?
Chingo is offline   Reply With Quote
Old 09-06-2012, 03:49 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 492
You need to eliminate the source of moisture, then elimimate the mold. Painting over it will do NO good, it will just come back through the paint.
The Following User Says Thank You to chrisn For This Useful Post:
user1007 (09-07-2012)
Old 09-06-2012, 06:48 AM   #3
Gymschu's Avatar
Rewards Points: 932
Do a search on here and you will find DOZENS of threads on this very topic..........and, listen to Chris!
Old 09-06-2012, 08:44 AM   #4
Rewards Points: 394
If mold spores grow through paint film, the paint will ALL have to be removed. Mold cannot be encapsulated by paint. Make certain that there is sufficient ventilation (bath fan) to remove humidity.
Will22 is offline   Reply With Quote
Old 09-07-2012, 01:27 PM   #5
link plz,
so I should just scrap the paint off, like the layers off with the mold before painting?
Old 09-07-2012, 05:03 PM   #6
chrisn's Avatar
Rewards Points: 492
Originally Posted by Chingo View Post
link plz,
Already answered
Old 09-07-2012, 06:38 PM   #7
Too Short? Cut it Again!
You must source and kill off the mold. If it is hiding in the wall, the wall is going to have to be opened up. You might cut an opening and stick a mirror and flashlight in there to see what you are up against.
Now if the mold is growing because of moisture from the surface that is easier to address. You cannot skip the step or you will be at this eternally. There is no quick fix.
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 09:11 PM
Likely Mold Cause? mrvt Building & Construction 4 02-24-2011 12:21 AM
Mold growth in basement under shower. Need suggestions to fix leak and clean up mold vseven Plumbing 6 12-10-2009 02:33 PM
Old mold...new mold jackbonham Building & Construction 2 08-24-2009 06:06 AM
Mold around bathroom tub 99miles General DIY Discussions 1 08-15-2009 06:51 PM
