Painting Over Messed Up Sheet Rock. - Painting - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 01:57 PM   #1
Painting over messed up sheet rock.
My husband and I are remodeling our bathroom in a house built in the 1970s. Today I pulled off tile. However, it was applied to sheetrock and when I pulled it off It pulled off the top layer of sheet rock. There were also about 3 layers of wallpaper. Problem is this....Now the wall is all bumpy and uneven. I tried to sand it but that didnt work on the sheet rock and wallpaper. What should I do? I dont want my paint job to look uneven.
emilyiam is offline   Reply With Quote
Old 03-24-2008, 02:04 PM   #2
Oldguy
Rehabber's Avatar
You can cover it with another sheet of 1/4" sheetrock, or tear out existing and replace with new, (which would allow you to bring insulation to modern standards) IMNTBHO
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 03-24-2008, 04:00 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
The over-rocking would work
Otherwise, it needs to be sealed
Use a specialty sealer such as Zinsser's Gardz
After sealing, you could "smooth out" the problem areas with joint compound and taping/putty knives
You may find a layer of joint compound over the whole thing (a skim coat) is required
As it sounds like a bit of a mess, trying to fill in the spots that need it may get you pretty much a skim coat anyway by the time you are done
The j/c must then be sanded smooth, dusted,and then primed with a quality latex primer, or Gardz if you have some left over
Then you are ready to paint
slickshift is offline   Reply With Quote
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
What size sheet rock for garage ceiling? Billy Boy General DIY Discussions 12 01-24-2008 12:36 PM
Leveling floor first or putting up sheet rock? rncopper Flooring 3 12-03-2007 02:03 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Seed, Sod, or Rock? (opinions wanted) tigerbalm2424 Landscaping & Lawn Care 1 03-23-2007 11:51 AM
