Painting Over Marlite Ceiling In Bathroom? - Painting - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 09:32 AM   #1
Painting over marlite ceiling in bathroom?
My daughter has on older house and would like to spruce up her bathroom without alot of cost. Her ceiling in the bathroom was originally marlite paneling of some sort that has been painted over. Now the paint is peeling off. What type of paint or treatment could we use to repaint the marlite?
yoopergurl is offline   Reply With Quote
Old 08-16-2011, 11:11 AM   #2
Gymschu's Avatar
Rewards Points: 932
If you're on a budget, scrape as much loose paint off as you can. You want to get down to a sound surface. Apply a coat of Zinsser 1-2-3 primer to bond to the Marlite & repaint with a reputable paint such as Sherwin Williams or Benjamin Moore.
Old 08-16-2011, 12:23 PM   #3
painting over marlite
Should I use oil base or water base paint?
Old 08-16-2011, 03:53 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
I would use a paint specifically made for bathrooms.
chrisn is online now   Reply With Quote
Old 08-16-2011, 04:05 PM   #5
Gymschu's Avatar
Rewards Points: 932
Zinsser 1-2-3 is a WATER-based bonding primer.......and, as Chris suggested, the Perma-WHite latex is great for bathrooms. It, too is water-based.
Old 08-16-2011, 04:19 PM   #6
thanks for your help
Old 08-17-2011, 03:22 AM   #7
chrisn's Avatar
Rewards Points: 496
I believe the Perma White says it is self priming ( memory, not so good), in any case I would prime first with the 123, it cannot hurt.
Bathroom ceiling bubbled Proby Painting 7 07-19-2010 08:59 AM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Best way to texture a bathroom ceiling DIY-Renovator Painting 3 07-30-2008 09:49 AM
Soffit Running Thru Bathroom / Dropped Ceiling xlr8tn Building & Construction 3 01-23-2008 06:37 PM
excessive moisture on bathroom ceiling Den69RS96 General DIY Discussions 8 01-14-2008 08:37 AM
