Painting Over Latex Semigloss - Painting - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 07:31 PM   #1
Painting over latex semigloss
Could someone help with this problem? I just spent the entire weekend painting my bathroom. Now I realize that it is really too shiny and I would like to tone it done with a medium luster - somewhere between semigloss and flat. Can I paint directly over the latex semigloss with at pearl finish? I used Home Depot Behr premium plus ultra, which is a primer and paint in one.
Rats is offline   Reply With Quote
Old 01-28-2013, 07:38 PM   #2
Rewards Points: 13,712
You might want to hold off to see if you get used to it.
Reason being is in a bathroom it's best to go with a higher sheen, easer to clean, less poris so it resist stains and mold better.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jagans (01-28-2013), Rats (01-28-2013)
Old 01-28-2013, 07:59 PM   #3
A pearl sheen will be fine. You can go right over the semi-gloss. If you do it in the next 2-3 days you can go right over the semi. If you wait longer you want to give the semi a light scuff sanding with something like 150 grit sandpaper to cut the gloss a bit and create a bondable surface.
The Following 3 Users Say Thank You to jsheridan For This Useful Post:
chrisn (01-29-2013), Gymschu (01-29-2013), ltd (01-29-2013)
Old 01-28-2013, 09:32 PM   #4
Roofmaster
Rewards Points: 2,210
Joe is quite correct, as usual. You are much better off with SG in the bathroom, much less chance for mold build-up. I always use it, for what its worth, plus how often are you in there? It will look like gloss when you shower.
Old 01-28-2013, 09:38 PM   #5
Old 01-29-2013, 02:33 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
funny guy
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (01-29-2013)
Old 01-29-2013, 06:45 AM   #7
Gymschu's Avatar
Rewards Points: 832
To be perfectly honest here, mold grows on Semi-gloss just as easily as it grows on Satin..........it's the combination of moisture and something to feed on that makes mold grow.
Old 01-29-2013, 06:57 AM   #8
I was also told by a few that a even mildewcide is not a guarantee against mold. It discourages growth but, if the situation is ripe enough, mold will grow. It only prevents a foothold and from permeating the surface which stains. I've had blackened silicone and grout but never mold on ceiling or walls.
The Following User Says Thank You to jsheridan For This Useful Post:
painting latex over oil based paint macoretta Painting 6 07-17-2012 04:07 AM
Painting latex enamel over old polyurethane doors asmith4035 Painting 11 07-25-2011 01:39 PM
Painting dry basement walls: Drylok or latex? Ironlight Painting 9 04-16-2011 09:37 PM
Painting over latex and calcimine truebaca Painting 2 05-23-2009 04:54 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
