Painting Over High-gloss Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-28-2007, 07:58 PM   #1
Question
Painting over high-gloss paint
I need to paint a small bathroom that is covered in high-gloss water based paint. I want to do the minimum prep work necessary (who doesn't, right?) so I'm wondering if there is a type of primer that can be brushed on over walls that have been cleaned only, not TSP'd, and then just paint my preferred wall paint over that.
Any tips on doing it the easy way would be much appreciated!
Renee is offline   Reply With Quote
Old 03-28-2007, 09:20 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Some primers are more adherent than others
I wouldn't trust any of them on high-gloss paint w/o sanding first
Not one, sorry
Especially in the worst environment in the house-the bathroom
It doesn't have to be a "sand off finish" sanding, just a quick scuff sanding
I use a sanding screen on a pole and it would take (literally) only minutes to prep a small bathroom
Be sure to wipe off the dust after sanding
-for which I use a dry-type swiffer on a stick, also takes only minutes and works great
At that point, you may or may not need primer depending on what color's up there, and what's going up there
For example, if I was putting up Zinsser's Perma-White, I wouldn't even prime
That stuff is (truly) self-priming, and killer mold/mildew resistant
It's only limit is it doesn't tint darker than "medium" colors
And even those are getting iffy
Lights and pastels are no problem
slickshift is offline   Reply With Quote
Old 03-29-2007, 12:06 AM   #3
Pro Painter
It really is necessary to clean and sand the glossy surface.
The shower/bath walls have soaps and hair products on the wall, around the sink are other products. TSP might not be necessary but a cleaner that will cut through the soaps will be.
Sanding the gloss only guarantees your work. Bathrooms are detailed and time consuming. If not done incorrectly, they have to be repainted........after the failure is repaired.
If you don't want to use tsp, try laundry detergent, like tide. Use a rough cloth, like terry cloth, get the area wet and let it stay wet for at least 2 minutes. then wash, using moderate pressure, rinse. (this method won't work on flat paint)
For sanding, you can buy 1 sanding sponge, medium or fine grit, very inexpensive. All you have to do is rub the walls. The only object is to scuff the gloss (where have I heard that?).
joewho is offline   Reply With Quote
Old 04-01-2007, 03:27 PM   #4
Workaholic's Avatar
Rewards Points: 268
Not one, sorry
Ditto
Workaholic is offline   Reply With Quote
Old 04-18-2011, 01:09 AM   #5
Home repairs's Avatar
must scuff the substrate first..
Home repairs is offline   Reply With Quote
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 06:21 PM
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
Gloss Paint Just The One Painting 2 09-21-2005 12:00 PM
does high quality bargain paint exist? erica Painting 6 06-22-2005 05:53 AM
