Old 05-15-2012, 03:52 PM   #1
painting over glue
I pulled up old tile in my basement and painted it with oil base paint. the glue showed through still after 2 coats.. what to do???
TiffaniPlemons is offline   Reply With Quote
Old 05-15-2012, 04:14 PM   #2
Gymschu's Avatar
painting over glue
One of those cases where you should have asked the question FIRST before attempting to paint. At this point there's really nothing you can do unless you want to sand through the paint to get to the glue and then sand it down. Personally, I would live with it for now and consider it a lesson learned. Sanding the glue before painting would have been the route to go.
Old 05-15-2012, 05:55 PM   #3
paper hanger and painter
chrisn's Avatar
painting over glue
As gym said, kind of late now. You could try priming with a good stain blocking primer and go from there
painting a wall with glue still remaining Broberts Drywall & Plaster 1 05-05-2012 03:42 AM
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 10:21 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 09:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 03:16 AM
