Painting Over Freshly Screwed Up Stain - Painting - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 04:35 PM   #1
Still Learning
painting over freshly screwed up stain
Hey guys I built this shelf to go under my tv and I thought it would be a good time to stain it yesterday while I was drinkin and bbqin and its all jacked up. The stain I used had the varnish built in. Of was one of those two in one deals. Do I gotta sand that drug off before painting it or will the paint stick as it sits right now? I only put one coat of finish on that wood yesterday.
thehvacguy is offline   Reply With Quote
Old 06-02-2013, 04:54 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
You'll have to sand it. And/or use a bonding primer. If you sand it all the way off a regular primer might work ok.
If you want it to really bond well and not chip off, use a good bonding primer.
Jmayspaint is offline   Reply With Quote
Old 06-02-2013, 05:08 PM   #3
Rewards Points: 12,856
Most likly Minwax Poly Shades. Should have been taken off the market years ago.
Gymschu (06-02-2013)
Old 06-02-2013, 05:12 PM   #4
Still Learning
Damn so I gotta kiltz it? If I use kiltz do I still gotta sand it? It's a ***** cause it has fancy trim with grooves everywhere. It was supposed to look fancy. I should have gotten regular stain like I usually do...
Old 06-02-2013, 05:15 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Kilz is not a bonding primer. use Zinsser cover stain. Even a light sanding will help the primer bond better.
Old 06-02-2013, 05:16 PM   #6
Kiltz would be like poring milk on it.
You need a real bonding primer.
Or just start over.
Old 06-02-2013, 05:36 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
no such thing as kiltz anyway
The Following User Says Thank You to chrisn For This Useful Post:
Old 06-02-2013, 06:25 PM   #8
Gymschu's Avatar
Rewards Points: 230
Hit it with some 1-2-3, let it dry good, and paint it.
If you're using Polyshades, it probably does look messed up. That's a product that you have to apply in multiple coats to get the color/look you want. If it was pine, a preconditioner may have helped make it look less splotchy. In any event, prime and paint.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
ToolSeeker (06-03-2013)
Old 06-07-2013, 09:00 PM   #9
Still Learning
Yea I used miniwax pre stain wood treatment and polyshades stain and finish. That polyshades is garbage!!! If I sand it back down to the wood and use a regular stain would it work or do you think I should paint it?
Old 06-10-2013, 05:59 AM   #10
Matthewt1970's Avatar
Rewards Points: 1,098
How big of a shelf are we talking about here? I am thinking a couple cans of spray paint if it is small enough.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-12-2013, 01:11 AM   #11
Still Learning
It's 46" long 12 1/2" deep. I took a scrap piece of permalam and put moulding around the edge, plywood on top, and fancy brackets under it. I want to paint it as a last resort. I intended to make it look like mahogany...
Stain and polish concrete floor in basement fletchccc Flooring 0 11-30-2012 04:36 PM
painting over new solid deck stain passthepoi Painting 17 05-18-2010 12:36 PM
Ceiling Leak Stain Repair Help Please ltkenbo General DIY Discussions 2 09-13-2009 07:38 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
Exterior Door Painting vs. Stain paradis42 General DIY Discussions 1 11-12-2005 11:57 AM
