-   -   Painting over flat paint in bathroom (http://www.diychatroom.com/f4/painting-over-flat-paint-bathroom-40536/)
lewisj 03-17-2009 04:21 PM
Ok, I'm sure this has been answered before, but I just want to make sure that I'm doing the right thing...our house is 5 years old and we have been living in it for approx. 4. I decided 2 months ago that I wanted to paint our guest bath. Not knowing ANYTHING about paint other than what color I wanted, I chose a cheap (I know, I know) flat interior paint for the walls--we didn't re-paint the ceiling. The walls were originally painted a flat off-white color--I went for a medium brown--called "Ottertail"--we used 2 coats. Now, 2 months later, the paint is starting to discolor around the shower--blotchy darker areas, and I hate how chalky the flat paint looks. Obviously most of the problem is from the cheap paint and the humidity in the bathroom. From reading other threads on here, I know now that I should've used a paint made specifically for bathrooms and NOT cheap paint. So, what's done is done, but I want to fix it, because I am very disappointed in the result! First off, do I need to re-sand or re-clean the walls before re-painting? Secondly, do I need to use a primer over the flat paint, and if so, what is recommended? Third, what is a durable brand of bathroom paint (I don't plan on re-painting again for a long time if possible)? Fourth, do I need to go with a lighter color (I'd say it's about the color of chocolate milk now), and if so, would I need to prime it to cover the brown? Thank you for any help you can provide!!
slickshift 03-17-2009 04:49 PM
I would clean and sand just to be on the safe side
You also might want to use a quality primer also just to be safe
(the bathroom is the worst environment for paint to adhere, and you've got a few layers of cheap stuff on there right now, best to stack the deck in your favor)
Benjamin Moore and Sherwin Williams both have excellent Kitchen & Bath paints
BM's Aura also works great in this tough environment
All are "self-priming", but I'd still hit it with a coat of primer anyway, as we're not really sure of the quality of coatings thus far
Bob Mariani 03-17-2009 05:12 PM
many bath paints are self priming. The reason is the mildicide will move to the surface from the primer after it is exhausted in the top coat. I would use Zinsser's Perma White which you can tint to any color. Just clean with TSP and rinse first.
