Painting Over Exterior Gloss & Satin When Sanding Is Difficult - Painting - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 07:59 AM   #1
Rewards Points: 35
painting over exterior gloss & satin when sanding is difficult
I have some old exterior decorative moulding that needs to be repainted. One kind of moulding has been painted in satin latex, and another in gloss latex. Some of the paint is flaking off. I don't care what finish I paint it in and I can keep the same colors, but unfortunately it would be impossible to sand thoroughly. It is very detailed with lots of nooks and crannies.
What are my options? I have read some info on the internet and everything seems to mention sanding. Whatever I do, I would prefer it would last as long as possible.
skiposwald is offline   Reply With Quote
Old 09-24-2009, 08:57 AM   #2
NAV
you should power wash it to remove all contaminants that may affect the adhesion of the new paint coating
I like to use Sherwin-Williams Prep-Rite Bonding Primer for glossy surfaces that I can not or do not want to sand. the Bonding Primer will stick to smooth glossy surfaces.
there are cleaners you can use that will de-gloss but the bonding primer is the easiest solution to your problem
NAV is offline   Reply With Quote
Tags
gloss satin paint
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 10:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 11:02 PM
Sanding drywall after painting... argh! moneymgmt Painting 3 05-06-2008 08:25 AM
Painting a difficult wall. wfischer Painting 14 03-17-2008 06:03 PM
