Painting Over Epoxy - Painting - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 05:31 AM   #1
painting over epoxy
I have an epoxy basement floor. It has good adhesion no problems there, however, want to change the color. Its a dark grey and want to go gloss black. I understand that I need to sand it down to rought it up and remove the shine. Its the next step that has me going nuts. Since I want a high gloss, should I use an acrylic porch paint, or can I try a latex paint with a urethane over it? So confused need lots of advice. Thanks
TRACEY C.
tconenna is offline   Reply With Quote
Old 05-14-2013, 06:38 AM   #2
Jmayspaint's Avatar
Rewards Points: 534
I doubt you will have any luck going over the epoxy with an acrylic, unless the epoxy happens to be water base too. Even then I doubt it would be as simple sand and paint.
Sounds to me like you need some ' on site professional advice. Re coating epoxy products is not a DYI job IMO. Too much potential for disaster.
Jmayspaint is offline   Reply With Quote
Old 05-14-2013, 06:40 AM   #3
Rewards Points: 386
TRACEY C.
I'm curious - if you already have epoxy (and I'm assuming a 2-component epoxy), and are willing to do the necessary prep to re-paint...you want a high gloss black (which I don't think you'll find in an acrylic floor paint), and you'd be willing to put a urethane over the acrylic black to achieve the desired gloss, right? Why wouldn't you just stay with epoxy in a gloss black?
Epoxy on a basement floor is actually kind of overkill - but the problem is not all single component, conventional products are necessarily compatible with an epoxy coating. Stay away from alkyd coatings - acrylics have a better chance of a good bond - depending on what type of acrylic you're considering... but, in my opinion, you'd be just as well served going with a water-borne, 2 component epoxy coating (Stay with water-borne, there are several different brands that are available in gloss black). For what you're describing, it'd be less work, would possibly be even less expensive, and have a greater probability of success. Something to consider.
P.S. - And as you're considering this, keep in mind that gloss finishes can produce a slippery surface to walk or play on...
ric knows paint is offline   Reply With Quote
Old 05-14-2013, 10:52 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
I am with Rick. I wasn't a fan of water based 2 part epoxy untill recent. We did a Vet wash room with it (SW brand) and after the stuff dried you couldn't get it out of the buckets with a hammer and chizzel. Great stuff. And I think it smelled like laundry detergent.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 05-14-2013, 12:31 PM   #5
Too Short? Cut it Again!
I side with Ric on using an epoxy too.
If you want to try painting a small section take a look at Ben Moores porch and floor paint. The oil-based product is urethane reinforced and the waterbased product is epoxy reinforced. Whether either will hold up applied over epoxy is the question so you might contact Ben Moore customer support.
Note that the oil-base leaves a fairly high gloss film but the waterbased will be more like a semi-gloss.
Regular paints, even with a clear coat over the top, are not really built for foot traffic.
Old 05-14-2013, 12:39 PM   #6
Rewards Points: 394
A test patch for adhesion on the existing epoxy is always a good idea.
Will22 is offline   Reply With Quote
Old 05-15-2013, 05:09 AM   #7
Thanks to all
Thanks for the replies. There seems to be a question as to why not epoxy again? The floor is over 2000 sqft, dont want to go for the money with epoxy again. It may seem like overkill, but the area is actually an inlaw apt. gets alot of foot traffic. Behr makes a black porch paint, that is why I questioned the acrylic. Behr seems to get mixed reviews on this website. Well thanks again I guess Ill start calling reps and making test patches.
Old 05-15-2013, 06:03 AM   #8
Behr floor paint?
Old 05-15-2013, 05:02 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
that's just scary
Old 05-15-2013, 05:27 PM   #10
Rubbin walls since'79
Brushjockey's Avatar
And also realize that black is a housekeeping nightmare. Really.
Really x2. Believe it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-15-2013, 05:39 PM   #11
I believe it and would suggest 4x for high gloss black. Every spec of dust will show and every little smudge of anything.
Old 05-16-2013, 04:28 AM   #12
I know you must think" high gloss black" nightmare- but I'm already OCD with cleaning. Sometimes a girl wants what she wants (Im sure u experienced this). Thanks boys for your suggestions.
Tracey
Old 05-16-2013, 04:38 PM   #13
chrisn's Avatar
Rewards Points: 388
Tracey
Isn't that the truth
She usually gets it also.
Tags
epoxy floor
Epoxy painting over an existing deck that has epoxy paint Dennis OHara Flooring 1 08-25-2012 10:36 AM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 03:41 PM
painting epoxy on laminate countertops ronwalk Kitchen & Bath Remodeling 0 08-24-2010 09:19 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
