Painting Over Drywall -- What Kind Of Prep? - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2005, 08:22 PM   #1
painting over drywall -- what kind of prep?
My husband and I removed the wallpaper from our bathroom this week and realized that the builders had glued the wallpaper directly over the drywall with no primer between the drywall and the wallpaper so it was impossible to remove all glue. What kind of prep will be necessary before painting the walls to assure they are smooth? Should we put a primer coat and then sand it? Any suggestions as to what kind of primer would work best? Thanks for any advice!!
CindyF is offline   Reply With Quote
Old 12-29-2005, 09:54 PM   #2
747
registered
747's Avatar
Rewards Points: 534
Zinsser bulleys 123 interior exterior primer sealer stain killer(waterbased). Paint zinsser perma-white mold and mildew resistant interior paint. Eggshell. Definately sand the hell out of those walls before primer. Also with that primer once it dries run your hand over the wall you might just need to lightly screen the wall with a hand held drywall screen. Thats what i had to do. Make sure after you sand the walls you wipe them down with a damp sponge and let them dry. Once primer is on and dry you just take hand held drywall screen and just sweep over the wall takes like seconds. This is what i used on my bathroom and it turned out excellent. It was recomended by a painter buddy on another forum.
http://www.zinsser.com/product_detail.asp?ProductID=11
http://www.zinsser.com/product_detail.asp?ProductID=35
Print that out on there page and your good to go when going into menards or lowes. I went with menards they had it on sale when i did my bathroom.
747 is offline   Reply With Quote
Old 12-29-2005, 10:26 PM   #3
Contractor
Go with 747.
I do like Gardz, same co. but oil based. Best for cedar.
Teetorbilt is offline   Reply With Quote
Old 12-30-2005, 02:05 AM   #4
747
registered
747's Avatar
Rewards Points: 534
Oh i forgot to tell you. On the back of the can it will tell you what kind of brush and roller they want for you to use. So check that and buy that. Synthetic i think but double check.
Old 01-01-2006, 11:01 PM   #5
Paperhanger/painter
ProWallGuy's Avatar
Originally Posted by Teetorbilt
Go with 747.
Oops, Gardz is water-based.
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 01-01-2006, 11:26 PM   #6
Contractor
Sorry, Cover Stain is what I have switched to. Working best so far.
Old 01-12-2006, 01:54 AM   #7
Professional Painter
Zinsser's has a great product called Diff. This will remove the glue, which is essential before priming the wall. By removing most of the glue you should have a smoother surface and will require less prep time to get it smooth again.
After removing all of the glue you'll need to prime the wall 1-2 coats. After the prime, you'll need to do a light skim coat of drywall mud over any defects in the wall. You may also need to put 1 coat of color on the wall to bring out anymore imperfections. Once all the imperfections are fixed, do a spot coat only the bare dry patch, let it dry, then paint the whole wall. By painting just the patch, it will prevent you from using more paint then needed. You'll find out that if you don't do this "spot painting", then you'll see, dry halos where the patch was. You basically need to build the paint in those patched areas before painting the whole wall.
r0ckd is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
Painting drywall in garage Rod Painting 5 08-12-2005 07:36 PM
