Painting Over Dark Wooden Paneling - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 06:15 PM   #1
Smile
Painting over dark wooden paneling
Living in a small town, advice and opinions are variable. At the advice of one painter, I painted my paneling in kitchen and bath, with latex kilz, and latex paint. It looks good, but scratches easily, usually down to the original paneling.
I am going to paint another room, and was wondering about using oil based primer, and latex paint. Can someone give me some advice if that will work.
gene56 is offline   Reply With Quote
Old 08-15-2010, 06:34 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
yes it will
The Following User Says Thank You to chrisn For This Useful Post:
gene56 (08-15-2010)
Old 08-15-2010, 09:00 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Infact that is what you want to use.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
gene56 (08-15-2010)
Old 08-16-2010, 04:21 PM   #4
Drywall over the top, primer and paint.
Does the panelling have the standard vertical grooves? Are you filling those with drywall mud? They WILL eventually crack. Get some 1/4 or 3/8 drywall and hang it. You will be MUCH happier in the long run. This comes from experience.
unlvrebel is offline   Reply With Quote
Old 08-16-2010, 05:06 PM   #5
Rewards Points: 252
clean the panneling first with Mex or TSp or similar. A lot of times people will clean the paneling with murphy's oil soap, liquid gold, or a similar product which will leave a residue - this will prevent the primer from adhering well. After it's clean and dry, Prime with a good bonding primer - oil based primer would be best but I see no reason why you can't get away with zinsser 1-2-3, water based fresh start, or similar product - latex killz isn't one of the favorites here. After the primer dries, topcoat and you should be fine.
good luck!
mazzonetv is offline   Reply With Quote
Painting Paneling kb3ca Painting 1 07-06-2010 05:48 PM
painting paneling with a sprayer? b_corwin Painting 2 10-04-2009 09:28 AM
I Hate Ice Stubbie Off Topic 20 12-21-2008 12:41 PM
Tips for painting with dark colors pjm Painting 10 06-13-2008 10:07 PM
Painting Over Wood Paneling vomtickie Painting 8 08-01-2007 05:07 PM
