Painting Over Cracks In Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 07:18 PM   #1
painting over cracks in paint?
The paint in our guest bathroom has stange cracks throughout (see photo). It looks like the same paint that was used throughout the house, but I haven't seen anything like this anywhere else in the house. The home was new construction, but a foreclosure on the builder so I don't have anyone to call to ask questions. Would primer and a fresh coat suffice, or do i need to do something else? I'm confident in my painting skills, but i don't know anything about what needs to be done to make sure the cracking is taken care of, or why it cracked in the first place.
Thanks in advance for your help!
Leanne1 is offline   Reply With Quote
Old 09-25-2011, 08:08 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Could be a flat over a harder glossy surface+ humidity making to expand and dry at different rates.
It needs something ( a good primer) that will stabilize it.
here again ( for those playing at home) I think Zinsser Gardz is a good choice because it will penetrate and seal.
Finish with an eggshell that can put up with the changes, not a flat that will absorb.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (09-25-2011)
Old 09-25-2011, 08:13 PM   #3
Gymschu's Avatar
Rewards Points: 668
Good call on this one BJ.........the only time I've seen this type of "cracking" was in a bathroom without an exhaust fan. Once fan was installed and walls were properly primed & painted, the problem disappeared.
Old 09-25-2011, 08:18 PM   #4
Could that have been from an over application, a heavy one and done? Either way, follow brushjockey's advice. Sounds good.
Old 09-25-2011, 09:03 PM   #5
thanks so much!
Old 09-26-2011, 03:04 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
Could also be the dreaded paint over wall paper paste scenario.Still need to follow said advise.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Painting over unknown paint? Randall53 Painting 4 09-07-2009 04:40 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
repairing large cracks in paint joefromcal Painting 3 05-21-2009 09:08 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
