Painting Over A Concrete Skimcoat In Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 01:06 PM   #1
painting over a concrete skimcoat in bathroom
We had noticed paint alligatoring in the bathroom so we stripped this down and then we applied a 'skim coat'. BUT, the skim coat turned out to be this:
unipro Universal skim coat which is a floor patch. We bought the wrong type of skim coat. So can we paint over this directly or do we need to sand it down and put on a plaster or joint compound skim coat? Would a good primer such as Kilz or Zinsser?
Thanks.
benhogan is offline   Reply With Quote
Old 10-20-2009, 02:31 PM   #2
Too Short? Cut it Again!
Once it has cured you should be alright surfacing it and putting on a good latex bonding primer. I would use Benjamin Moore Fresh Start or MAB Superbond. You could also use an alcohol based masonry and concrete primer but I don't think you need to. Do not use an oil-based primer on a concrete surface though. The alkalai in the material will react unfavorably with it.
Concrete Sealer for Bathroom Dayle Concrete, Stone & Masonry 9 02-07-2012 08:11 AM
Leaking bathroom drain. Concrete subfloor... Help crashtah Plumbing 2 05-27-2009 05:42 PM
Painting Bathroom Cabinets tmcguirk Painting 1 03-16-2009 01:13 PM
painting concrete victor Painting 3 08-06-2007 10:44 PM
