Painting Over Builders Grade Exterior Paint - Painting - DIY Chatroom Home Improvement Forum
Old 07-23-2009, 10:11 AM   #1
Painting over builders grade exterior paint
I am painting the outside of house. It is 9 years old and has builders grade exterior paint. The paint has begun to go chalky. Most of my painting will be the two story soffits and siding that is on the second story (brick on most of first story). My questions are:
What is the best way to get rid of the chalk?
I assume that pressure washing is going to be one of the suggestions. How much PSI do I need? 1200psi, 2500psi, 3000psi...
How much of the chalk will pressure washing remove?
Will I be able to pressure was the 2nd story from the ground or need to get up closer with a ladder?
I plan to prime the exterior to ensure good bonding over the old paint.
What is a good primer to use?
The bigbox stores have Zinsser 1-2-3 for $20 and my other option the BM primer at $30
As for paint I plan to go with BM MoorGard.
wolverine45 is offline   Reply With Quote
Old 07-23-2009, 11:45 AM   #2
NAV
Power wash
2,500 psi or higher
all of it if you do it correctly
They sell extension poles but if you dont know how to use them you better get a ladder
you dont need a bonding primer, just an exterior primer. Unless you are painting over a glossy surface. It is a safe way to go giving it a 100% prime but not necessary
Sherwin Williams A-100 acrylic primer is good enough
I dont like Zinsser on exterior applications. BM is always a good product
have at it
NAV is offline   Reply With Quote
Old 07-23-2009, 11:56 AM   #3
Any experience with a "ladder saver"?
The thought of getting up on a 30ft extension ladder with water going everywhere does not excite me.
http://www.pressurewashersdirect.com...S55/p1922.html
Old 07-23-2009, 12:03 PM   #4
NAV
NO, that is just a 0 degree tip on a pressure washing wand, you will not get the pressure you need. plus, if you hit something from close up it will blast a hole in the wood or break a window.
sorry, your choices are ladder or extension pole.
Old 07-25-2009, 07:35 PM   #5
100 Year Family Tradition
4ThGeneration's Avatar
My 2 Cents
This comes from cheaper paints being used. TSP will help, but use low pressure when doing this.
It is never about PSI when washing anything, but concrete. It is about water flow. Get one 4.5 GPM or better.
If you use the right chemical you will have no problem.
They have telescoping wands you can use, but if you have a 4.5GPM water flow along with a higher HP engine you will be able to downstream atleast 30 feet or higher.
Dull, clean and dry is the surface you need to have. If you have peeling and cracking paint you need to scrape off what is falling off. Then you can feather sand smooth.
Benjamin Moore
Benjamin Moore. It has a very high content of Acrylic. When you wash your brushes out with soap and water. You have to rinse spirits through it in a 1 gallon empty paint can and then re rinse in water.
You want to use this because of the low lustre?
4ThGeneration is offline   Reply With Quote
Old 07-27-2009, 12:27 PM   #6
NAV
4ThGeneration
If it isn't about pressure then why even use a power washer? couldn't you get the same results from a garden hose?
Old 07-27-2009, 08:50 PM   #7
Originally Posted by NAV View Post
4ThGeneration
Its about the chemicals used. the right chems can remove just about anything. I have a 4.5 GPM 3500 PSI with 14 HP pump. I clean about everything with a 0040 tip.
If you want an example it would be best to look here at some people I am friends with.
House Wash With A Ball-Valve And Down Streamer
Have a ball, no pun intended.
Touching Up Builder's Grade Paint - HELP!! candisue7 Painting 8 04-26-2009 03:52 AM
Painting over builders grade paint ryan16 Painting 9 03-04-2009 09:38 AM
Priming "builders grade" paint before painting Plasmech Painting 10 03-30-2008 01:37 PM
