-   -   Painting over Behr kitchen cabinet paint (http://www.diychatroom.com/f4/painting-over-behr-kitchen-cabinet-paint-97192/)
heimster14 03-04-2011 12:02 AM
My husband and I want to paint our cabinets again. The first time we use Behr Kitchen premier plus paint. (I think that is what it is called). Bad experience. Anyway, we want to use the Benjamin Moore Kitchen and bath. My question is what type of prep work do I need to do? Do I go as far as stripping the Behr from the cabinets before primering with Benjamin Moore? Thanks for anyones response.
jsheridan 03-04-2011 02:32 AM
If it's not peeling or chipping, no need to remove it. Prep involves sanding the surface, washing it down with Trisodium Phosphate and water, then apply your Ben Moore. As long as the current finish is bonded to the surface, no removal or priming is necessary.
ccarlisle 03-04-2011 06:38 AM
I'm no pro, but I think most kitchen finishes are somewhat glossy and therefore in order to paint over them, a sanding is required for better grab.
You don't say what the problem was with the Behr, if it was the paint job, or the paint - but it might have been due to poor preparation. After all, prep is 80% of most paint jobs - particularly tough ones like this.
So, depending on what problem you had originallly, our response to how to fix it might differ. For example, if you didn't remove the greasy film on them before painting, no paint job would work - regardless of who's paint you used. But if you did remove the grease and sanded it, but don't like the colour, the prep would just involve IMO a good cleaning and sand paper.
NCpaint1 03-04-2011 07:27 AM
604-PAINTER 03-05-2011 02:27 PM
hi heimster
dont use Benjamin Moores Advance
stick to an oil eggshell for best results (assuming that you dont want to use lacquer) benjamin moore touts their new Advance (a hybrid latex/oil) paint as the best thing since sliced bread. We tried it on one cabinet job recenty and got our butts kicked. it never really cures and chips off quite easily. I just called a customer two days ago to ask about how the Advance job was holding up. He is a very polite and soft spoken customer but he was very quick to say "my cabinets are sh --t" The Advance performed so poorly than I got all my money back from Bejamin Moore for the cost of the product for that paticular job (about $260.00) We do a ton of cabinetry work and will never use this paint again. Ive also spoken to the Benjamin Moore reps in my area and they all are saying that a ton a lot of complaints are coming in about this product. Just a friendly heads up.
regards
ra
www.vancouversbestpainters.com
www.vancouverindustrialpainting.com
Matthewt1970 03-06-2011 08:30 AM
These cabinets already have latex on them. Oil is out, except for oil primer.
NCpaint1 03-06-2011 08:44 AM
NCpaint1 03-06-2011 08:47 AM
NCpaint1 03-06-2011 08:53 AM
housepaintingny 03-06-2011 09:56 AM
Originally Posted by NCpaint1 (Post 603512)
You called your customer 2 days ago? Yet you've already received a refund on the product? That's pretty fast. Did your Rep visit the job to ensure it was applied correctly? All of that being completed in 2 days...on a Weekend mind you, is pretty quick. I call BS
Like you said. First a rep. Would look at the job to make sure the application was correct and then if they determined there product was bad it will still take more than 2 days to get a refund. If the paint failed with in two days I would say its due to application error. I've never used the advance, but have used SW Pro Classic enamel, which also comes in a water clean up formula and I'm sure its similar to advance. Never had a problem with the Pro Classic. I would recommend an enamel also.
604-PAINTER 03-06-2011 11:09 AM
we started the cabinet job 2 months ago and one day into i quickly realized that the product we were using, Advance, was garbage. i called the owner of the store and asked for a full refund, which he gave immediately. (he owns 5-7 stores) We contemplated changing products but decided to complete the job with Advance. 4 days ago i called the customer to see how it was holding up as I was interested in using this person as a reference. the customer told me his cabinets get discoloured when washed and chip easily. then he said that his cabinets are "sh--t"
Our application was perfect.
No bs here painter, just the facts.
Something is bound to go wrong when you start formulating incongruous wonky things like a latex/oil hybrid.
www.604painter.com
604-PAINTER 03-06-2011 11:13 AM
No applicator error here hpny. No rep showed up as i dealt with the owner of the store. it didnt take more than 2 days to get a refund, it took 15 minutes. Tons of complaints coming in about this product. it also doesnt tint up well either.
ra
www.604painter.com
604-PAINTER 03-06-2011 11:19 AM
hi mathew
not always right but never in doubt eh. i like your confidence but you have it reversed. oil over latex, cool, latex over oil, not cool... cheers
ra
www.604painter.com
NCpaint1 03-06-2011 11:38 AM
StevenH 03-06-2011 11:49 AM
Originally Posted by NCpaint1 (Post 603639)
The technology of mixing oil/water isn't new. In fact Moorgard/glo/life as been a hybrid product for over 15 years.
Embrace the new technology, with VOC laws becoming stricter, its only a matter of time before oil products as we know them will be obsolete.
Have any of you guys used Moorglo Semi-gloss lately?
It seems the stuff does not like to level itself.
